odd steering
Old Apr 14, 2011 | 06:57 PM
JD311's Avatar
odd steering
Been a while since I'v been on here.I have 2002 3500 4x4 drw.My prob is when I come out of a turn and the wheel comes back to center it feels like its crabwalking as if it was 4wd.When I make the turn the wheel feels fine.Only when I come out of the turn the wheel shakes.Truck drives fine.No shakes wobbles or vibration.165K on the od. Thanks for any info.
Old Apr 15, 2011 | 11:19 AM
DIESELWRKS's Avatar
check your wheel bearing / hub bearing. pull you wheel off and turn it, check you play on your ball joints, check the play on your track bar, do a general over all look at all of your steering linkage while your there. if your exhaust is really loud you may not hear your wheel bearing acting up.
Old Apr 15, 2011 | 07:12 PM
JD311's Avatar
I'ma check it all out tomorrow.Didn't these models have a hub problem to begin with?Recall readin somethin in dieselpower mag bout the hubs on these trucks haveing issues.
Old Apr 16, 2011 | 03:38 AM
DIESELWRKS's Avatar
the problem is its a bad set up being sealed hubs. you have to replace the whole thing. 250-400$ pending where you get them. plus not fun to replace. but it may not be that. if you can put the truck on stands with blocks on the back have some one turn your wheel while you watch all steering goods.
ramtradxb
13
Jul 7, 2011 11:03 PM
dkinzer
Aug 16, 2003 01:00 AM
BigBlue
Jul 9, 2003 02:19 PM
Sportfloor
16
Jun 5, 2003 07:57 PM
cr1998
Dec 26, 2002 09:23 PM
