NV5600 Overfill Question
Old Aug 21, 2007 | 02:46 PM
supr's Avatar
How many of you add 1-2 quarts extra and why?
At the same time , how many do not add, or even change the tranny oil and why?
There is an opinion that if you haevy tow, it may be highly recommended.
Old Aug 22, 2007 | 11:04 AM
SIXSLUG's Avatar
+ 1 quart. Gets more lube to the rear bearing. That Texaco "lifetime" fluid is vague in my opinion... it says lifetime but not as to the lifetime of what! I run the Redline MTL because I don't tow a lot of weight very often. Some guys prefer the Amsoil Severe Gear 75w140 that heavy tow.
Old Aug 22, 2007 | 03:30 PM
tmccormick's Avatar
Changed mine a few weeks ago and what came out didn't look all that bad but since I do tow some and have been getting some griding going into 4th (if I shift it to fast) so I thought why not.
I got just about 5 quarts in it by driving the truck up on ramps on the drivers side. Used Pennzoil syncromesh.
At first the shifting didn't change but after awhile it did get better
Old Aug 22, 2007 | 08:02 PM
afoulk's Avatar
I thought the over fill was done so the input shaft bearing wasn't starved for oil when towing up a steep grade?
Old Aug 27, 2007 | 03:18 PM
supr's Avatar
I think the theory is that the rear gears do not get enough lube when towing heavy. For the cost of 1 quart of lube, sound like a no lose proposition.
MountainBen
Oct 6, 2009 05:20 AM
TIMMY22
Feb 15, 2009 05:01 PM
BearKiller
Jun 16, 2007 12:01 AM
k-oss
Apr 9, 2007 03:40 PM
Dieselcamper
Jul 18, 2006 11:05 AM
