Noisy rear end
Old Mar 9, 2009 | 10:32 AM
Doug Crall's Avatar
Noisy rear end
I have just receintly noticed my rear Dana making a grumbeling noise in corners and more so when under acceleration in corners. I am not sure if my rearend uses clutch packs or cones. Any suggestions?
Change oil, different aditive? Check oil?
I am driving on stock size street tires and have aprox 120,000 miles
Old Mar 9, 2009 | 08:41 PM
dozer12216's Avatar
Change diff lube and add two containers of antilock additive. Do slow figure eights to work lube into clutches. Evulate for week.
Old Mar 9, 2009 | 10:10 PM
Doug Crall's Avatar
I just found it low and added a quart, if that dosen't clear it up, I will follow your suggestion, do you have a recommended additive?
should I have something to drink prior to the figure 8's?
Old Mar 10, 2009 | 01:08 AM
kstinson's Avatar
The recommended additive can be found at most auto part stores. Just ask for Limited Slip Differential Additive, or Friction Modifier for Differentials. If that doesn't help my suggestion is to get a dial gauge setup and check the backlash on those gears. If its off then you probably need a rebuild.
Old Mar 10, 2009 | 09:40 AM
mslashbar's Avatar
Check your pinion and wheel seals, if you were a quart low you probably have a leak somewhere also.
Old Mar 10, 2009 | 09:52 AM
Doug Crall's Avatar
I drove the truck to work this morning, and no noise. It supprised me to find it a quart low, the wheels are clean and dry as is the pinion and rear cover.
I'll have to watch it close for a while
pahskahl
Aug 5, 2011 02:52 PM
1999blackcloud
Jan 26, 2010 08:52 AM
doorguy
Jun 8, 2007 06:19 AM
royta
Jul 13, 2004 06:54 PM
Marine
Nov 2, 2002 10:48 PM
