no power and black smoke
hey guys i got a 98.5 and i just put a new vp and lp in and still got no power and no turbo boost.i checked all my elek conetors and tested my map sen and checked all my boots to my turbo all are good.i tryed this stuff with my edge box on and off still the same i pull a p230 code can someone give me a idea what to do next.
Do you have guages on your truck... (Fuel, Boost, Pyro) - Please report these numbers it might give a clue. If you don't have guages you really should go get some....
Check you intercooler boots for holes... What kind of boost pressure you seeing? (If any)
What kind of fuel pressure do you have? Really kind of wondering with a P0230 (Fuel Pump primary circuit) error.
At full load the boost should be up to about 18-20 PSI! You not making enough boost!
In return the EGT Temp is rising... My normal temp under load on a 6% grade in 5th gear is about 800-1000*F
Look for leaking boots from the turbo to the intercooler and up to the manifold.
Make sure your wastegate isn't stuck open.
You might want to recheck the turbo again for bearing play..
RJOS
16
Sep 3, 2007 09:19 PM
BuildingBoost
Mar 25, 2007 07:46 PM
BlackSheep5
Nov 27, 2006 07:52 PM
bensdad_canada
May 9, 2005 10:56 PM
