No 4wd
Old Feb 5, 2010 | 12:15 PM
matthais's Avatar
Originally Posted by shuie
Quick update. I shorted out the wires going to the 4wd switch and the light came on. So I ordered the conversion to eliminate the vacuum. It should be here next Tuesday and installed that night. Thank u guys so much for your help.
I can get pics of the install of the manual posi-lok kit if you want NAPA has them. but first I would highly recomend looking at rockauto.com the vac diaphram is 76 bucks plus shipping.
Old Feb 9, 2010 | 09:03 PM
Timberman's Avatar
I just started having this same problem tonight with my '99. We've been getting pounded with snow the last couple weeks, and I've been pulling my gooseneck and skidsteer all over creation, most of the time in 4 hi, some fairly frequent but short uses of 4 low. Now all of a sudden no light and no 4wd.
Do '99 trucks have the CAD? I can't even crawl under there to look at anything, its caked up with some serious ice and road salt. Got to plow all day tomorrow too, this sucks! Anything I can check for that hasn't been mentioned in this thread, that is different on a '99?
Old Feb 9, 2010 | 10:13 PM
matthais's Avatar
it the same on the 99 have had mine freeze b4
Old Feb 10, 2010 | 04:32 PM
Timberman's Avatar
Mine was a knocked off vacuum line. Big chunk of ice built up on the skid plate and pulled it loose. Got it working again but the dash light is not on now. It was on earlier, then I shifted from 4 high to low and it couldn't lock in, finally got it to lock in 4 high again after a lot of cussing and threats and I'm gonna leave it there til this storm ends.
The way the flimsy little vacuum hoses are routed down to the skid plate under the transfer case is dumb as hell. The skid plate acts like a flat shovel in heavy snow, and I'm amazed the lines stayed connected as long as they did. I am ordering the kit to eliminate the vacuum system. Good thread, thanks guys.
Old Feb 14, 2010 | 04:47 PM
GBRACER's Avatar
Thumbs up
I just did a diagnosis on my 4X4 not working after reading this thread (good info) I did the following.
There were no lights on the dash with the key on and no motor running.
Probably not on the start up sequince...????
I got a vacum gauge took the two hoses off the actuator and stuck a hose on one of them started the truck cycled the 4x4 lever and I got vacum, I stuck the gauge on the other hose and got vacum in the opposite of moving the 4x4 lever.
Took the actuator off the axle 4 12mm bolts and blew thru the hoses on the actuator the arm moved but there is a leak in the diaghram, so I ordered a new actuator will come tomorrow and cure my problem this all took 15 minutes to figure out.
Hope this helps.
Grant.
Old Apr 20, 2010 | 07:59 AM
RowJ's Avatar
Originally Posted by sheriffav8r
If 4WD can't be engaged (lights work when you put the key in to start, but not when you shift) then your CAD is probably bad.
Pulled this thread back up because I lost 4x4 also. Found the problem....lost vacumme.
But in the process I discovered I do not get a 4WD light when I turn the key on, but light IS working.
Can't remember if I ever did.... just always assumed so!
Does anyone else get 4WD light (with all the warning lights) when you turn the key.....pre start?
RJ
Old Apr 27, 2010 | 12:50 PM
RowJ's Avatar
Tried several repairs to the place where the soft vacume lines meet the hardlines (on the passenger frame rail).
After splitting the plastic lines twice I did not have enough left to work with.... and every sleeve I tried would come loose after a day or two.
Long story short.... Entire vacumme line from the transfer case to the front axle is a one piece item. Single part #.
But, it's the first reasonably priced part from Dodge I've found. (under $40.00).
And it's the first R&R repair job on my 02 that was easier than it looked!
Put Zip ties on both ends of the vacumme lines to be sure they don't come loose again.
Probably overkill, since the factory lines lasted 200,000 miles and 7 yrs.
RJ
Old Apr 30, 2010 | 04:38 PM
speedfreak237's Avatar
I just tried mine and I get no 4x4 light on the prestart. Only when it is engaged.
Old Apr 30, 2010 | 05:34 PM
patdaly's Avatar
I forgot to post as well, on the 97 the 4X4 light also does not come on during the pre-start light test.
93Fury
Mar 31, 2010 01:33 PM
wrangler04
Jul 17, 2007 11:00 PM
VikingDiesel
Competition / Pulls / OffRoad
Dec 29, 2006 07:17 PM
95black2615
Dec 20, 2006 06:37 PM
1320
May 6, 2003 06:30 PM
