Newbie Fuel Question
Old Dec 13, 2007 | 08:37 AM
Chuck Fox's Avatar
I've been reading a lot about fuel problems, and not sure what I should expect. I just purchased truck a year ago with 90K on the odometer. I'm wondering can someone tell me what to look for in my truck to see if there were any fuel upgrades completed before me? Also i'm assming I should add fuel pressure guage, and I'm wondering what I would do with the information? Is there a certain fuel pressure we should be maintaining?
Thanks for any help...
Old Dec 13, 2007 | 09:11 AM
PChouinard's Avatar
Go to UserCP and fill out the sig. You need to let everyone know what you are driving in order to get any help.
Old Dec 13, 2007 | 10:16 AM
Chuck Fox's Avatar
oops forgot my sig
Thanks, I think I got it right now...
Old Dec 13, 2007 | 11:23 AM
6WHEELER's Avatar
As for fuel upgrades. if you still have the lift pump mounted on the drivers side lower rear portin of the block which sends fuel to the injection pump, it's stock. trace the fuel line back to the tank and if there is no other pumps in the line it's stock. the factory lp will be just below the fuel filter canister and have a steel line (about a foot long) running to the injector pump. Don't quot me my mind is overworked right now, but I think stock pressure should be 10 to 12 psi at idle, no less than 5 or 7 psi at wide open. If that pump is not there and no other pumps in the line to your injector pump then you have the stock replacement in-tank pump.
Old Dec 13, 2007 | 05:40 PM
Awall's Avatar
Yea probably gonna want to getta fuel gauge (guage is preferrable to warning light). Now if its readin the right pressure and ya dont plan on bombing your truck then I wouldnt get a new one. If it aint broke dont fix it. If you do end up needing a new one then i'd recommend the Holley Blue, good pressure and reliability (at least in my case) and about 125.00 ish. Jus my .02
Old Dec 14, 2007 | 08:29 AM
Chuck Fox's Avatar
gauges and silencer ring
Thanks, I think gauges is where I'll start, I was looking at using the upgraded pillar with three gauges in it- I'm assuming fuel pressure, tranny temp, and turbo boost would be my most usefull choice?
Also I was reading in a lot of the posts about removing the silencer ring? Is that a good idea and is it something I can do myslf? And what are the benefits?
Thanks- so many questions, so little time...
Old Dec 14, 2007 | 11:48 AM
6WHEELER's Avatar
Fuel pressure 0 to 30psi gauge, boost 0 to 60psi gauge, Egt gauge most are 0 to 1600. These are the ranges I have. Egt will help more with monitoring the engine, exhaust temps can tell you alot about what is going on with the truck and tell you when to back out of it a little(so you don't burn it up). I would do the trans gauge last. I am running all four also,I put the trans temp on the steering column and the others in the pillar, boost up top, egt in middle, fuel pressure on the bottom.
uglyscout
Sep 29, 2008 02:01 PM
MoparNut
Dec 18, 2006 08:04 PM
davedye
Nov 17, 2006 03:17 PM
shooter_d
Oct 23, 2006 02:13 PM
