Newbie Differential Question
Old Sep 9, 2007 | 11:51 AM
bmatthe1's Avatar
Question Newbie Differential Question
Hi everyone. I'm new to this, but I have a question about my newly purchased '99 24v 4x4 QC Short bed 2500. The rear Diff cover shows a date stamp from '95 so it is not original. It has a wire connection to the top of it, which is disconnected. The Diff cover shows a stamp of: 46293 2, and then 077 9 and then RE D, and then 09 07 95. The removable tag shows 52069469AG, and then 3.54, and then 606148. Another tag under a bolt says "use limited slip lubricant" . What have I really got here? The reason I am interested in all this is that when I'm turning at very low speed, I hear a groany chatter noise from the rear. So I'm curious what the electric connection is for, and how to stop the noises.
Old Sep 9, 2007 | 12:12 PM
Dazeys's Avatar
The connection is for the ABS. Use some friction modifier to stop the chatter.
Old Sep 9, 2007 | 06:48 PM
fschiola's Avatar
Welcome to the site! What was posted above, and you have a 3.54 ratio gears. You can get the friction modifier at the dealer. If you plug the connector in and the ABS and brake lights come on, pick up a speed sensor while you're at the dealership.
Old Sep 12, 2007 | 11:58 PM
freedomrider's Avatar
just another quick remark. The need for limited slip lube "whale snot" indicates the rear end is a posi unit. Both wheels drive when you turn, one wheel ends up rotating faster than the other. There is a clutch in the diff which drives both wheels, & also slips enough to allow for the faster wheel. The anti slip lube aids in this, letting the clutch slip smoothly
Old Sep 13, 2007 | 04:33 AM
fschiola's Avatar
Make sure when you add the friction modifier that you don't fill the diff too full. The fluid should be 0.75" below the bottom of the fill hole + - 0.25".
Old Sep 13, 2007 | 06:44 AM
Tocapet's Avatar
And you can get the friction modifier either at the Dodge or Ford dealers. It's the same stuff and costs about 5 bucks for 4 ounces. It's called XR or something like that.
Old Sep 13, 2007 | 01:43 PM
RowJ's Avatar
The 606148 # is not for the automatics....so assume you have a Dana 80 rear end.... 5 sp or 6 sp tranny?
Assuming the tag goes with that rear end, sounds like just needs friction modifier... as mentioned above.
Go to a dealers parts dept, with your vin# and they can print you a 'build sheet'. It will tell you what came on the truck from the factory. Nice to have.
RJ
Sootman
Aug 17, 2005 06:28 PM
BIGBADBOB
Feb 8, 2005 11:12 PM
eswartz
Sep 16, 2004 06:52 AM
Planetcat
Sep 9, 2004 05:48 AM
Mike4122KSA
Dec 17, 2002 08:56 PM
