New VP44 Installed.
Old Sep 1, 2005 | 07:59 AM
SilverRam01's Avatar
New VP44 Installed.
Well board;
I Bit the bullet, and installed a rebuilt Bosch VP44 yesterday afternoon. Ended up taking it to a Bosch shop up in Watertown, SD. About an hour away, but they were very reasonably priced in comparison to all others I checked with. I paid $1325 total.....R+R. I was pretty pleased considering the dealer wanted $1425 for the pump, and another $400 for labor. No dead peddle all the way home.
I've got a one year warranty on this pump.
My only dissapointment, was that the intermittent miss at idle after the engine is warmed up, is still present. It's not a very prominent miss.....but the every couple seconds it's like the engine stutters.....if you watch the tach, you can see it jump just a little. Anybody have an idea what this is? Guess I may just have to live with it for the time being, unless it's a simple fix. (I'm pretty broke now)
Thanks to everyone who contributed on my VP44 issues. I hope my fuel system will be A - OK for a long time now. Plan on replacing my plastic nylon fuel gauge line with stainless,.....and monitoring that guage pretty closely in the future.
Old Sep 1, 2005 | 08:32 AM
MKELLY's Avatar
That's a great deal, I paid 1,800 out the door for mine . Good Luck
Old Sep 1, 2005 | 08:36 AM
99 cummins's Avatar
In my case that miss in the idle was from clogged injectors that I suspect resulted from lack of fuel pressure while the pump was bad. It's an easy thing to pull and check the injectors just in case.
Old Sep 1, 2005 | 09:27 AM
Supermod56's Avatar
You should take this opportunity to put some Mach-1 Injectors in it!!! You won't be sorry, got to get home to stuff mine in!! Probably is an injector issue
Tom
Old Sep 1, 2005 | 09:56 AM
2500CTD's Avatar
Can you actually feel it when the tach neelde "wiggles"? If not I believe I have read its normal, for the tach needle to move. IIRC the tach doesn't constantly read the engine rpm but rather samples it at a pre determined rate, and eveyno and then it will be different than the last sample and the tach shows this. mine does it to, but I dont feel it, just see the needle bouncing.
Old Sep 1, 2005 | 09:59 AM
Yes, you can feel it miss while sitting in the cab......and it's pretty audible standing alongside the pickup. I'll look into the injector issue. Maybe try a bottle of Lucas injector cleaner? Anybody else have any suggestions for a good injector cleaner ? I typically run Powerservice.....it hasnt seemed to make a difference.
Old Sep 1, 2005 | 10:20 AM
99 cummins's Avatar
I ran all the different cleaners all the time. I would change brands off and on just to cover all the bases. Did no good at all. I'm sure it helped keep things lubed but did nothing to keep from clogging. At 140,000 miles I had 2 stock injectors totally clogged.
Old Sep 1, 2005 | 09:18 PM
Cumminsdieselboy's Avatar
Muted User
Hey, we got the same problem, we are getting another new injection pump. Seems they are having trouble with rebuilt pumps lately. So i just thought i'd tell you my story and it is probably the injection pump. Becuase my thing about the injectors is, did it have a rough idle before the new pump, not in our case. Just giving my $.02.
I know if DonM reads this he has at least 3 trucks doing the exact same thing.
Cody
Old Sep 1, 2005 | 09:43 PM
AAmeeting's Avatar
Could also be the crankshaft sensor. It is a cheap-er fix.
Old Sep 2, 2005 | 02:51 PM
Cody
I really dont think it's my pump. It was doing the exact same thing prior to replacing the pump. New pump.....same intermittent miss. Only does it after the truck is warmed up.....Idle's as smooth as can be right away in the morning, but after 15-20 mins of running.....if you let her sit at idle......it misses ever 5 secs or so.
Old Sep 2, 2005 | 03:38 PM
Marine's Avatar
Veteran: Marine Corp
I've used Powerservice almost since new. You can take a look at my injectors in my Gallery. I changed them at approx 95,000 miles. No plugged holes. However, I did have a little surge/miss until I put the Comp on. Now it is very smooth.
Mike
robinlh
71
Oct 12, 2010 11:38 PM
95black2615
Jul 24, 2010 06:21 PM
whitetop
Apr 11, 2010 10:45 PM
hillbillymudrun
May 20, 2008 12:01 AM
89dieselkong
Jan 31, 2008 06:30 AM
