New vp44
Old Jul 7, 2005 | 07:42 PM
PaulG's Avatar
Question
Haulin,
Do you have a part number for the updated pump bracket? Thanks.
Old Jul 7, 2005 | 08:47 PM
Haulin_in_Dixie's Avatar
I don't have the part number, just tell Cummins what you want, they should have it in stock.
Old Jul 7, 2005 | 09:38 PM
Cumminsdieselboy's Avatar
Muted User
do ya'll think the blue chip pump would be better than a hot rod VP-44? and if not who makes a hot rod pump i tried searching everywhere and i cant find anything. just wondering. our white truck has had the 216 code for about 2 months deleted 2 months ago checked again today, came back. so well be needing one shortly.
Thanks
Cody
Old Jul 8, 2005 | 07:09 AM
j-fox's Avatar
I understand Blue chip will make a Hot Rod pump if you request it.
I just put one of the BlueChip pumps on mine last night. Install went very well and it starts better and sounds right, but will report back tomorrow on the perf.
Old Jul 8, 2005 | 06:23 PM
PaulG's Avatar
Thanks Haulin. I'll just give Cummins a call.
I also ordered a Blue Chip replacement pump. Mine just arrived today. I hope to get it on by Monday, so I will report back my impressions. Just shy of 90k miles on my '99 and this will be my third VP-44, so I hope it lasts a while this time.
Old Jul 9, 2005 | 06:47 AM
j-fox's Avatar
Ok, after a day of driving, it is nice to have it running smooth. I ran it up to the gov, in first to see how it was. When it was stock--before any mods--- it would sopund like a miss-fire at 2800rpm and above.
That is all gone and it pulls fine past 3000.
Of course that isn't real important to me, as I seldom go over 2200, just want it to run correctly.
Now, I am after any mileage changes. It would be nice to get back to 20-22 highway. I have seen as low as 12 with this pump acting up. With, about 16-17 every day numbers.
Old Jul 9, 2005 | 09:06 PM
PaulG's Avatar
Post
For those who are interested, the Cummins part number for the updated pump support bracket is 3938707.
Old Jul 10, 2005 | 10:29 AM
greenworks's Avatar
I just replaced my vp yesterday and the rear support bracket is a solid unit on a 01 it has two torx bolts that bolt to the pump and two bolts that bolt to the engine, I can't see having anything more sturdy maybe the older engines used a different mount.
Old Jul 10, 2005 | 12:08 PM
PaulG's Avatar
Well I just got my old pump pulled, and it looks like I already have the new bracket. The new one I bought at Cummins is exactly the same. So I don't know when they made the change in brackets. My truck did have the pump replaced before under warranty, so maybe they updated the bracket then.
Old Jul 10, 2005 | 12:56 PM
It has been updated, the '99 did not come with it.
Old Jul 10, 2005 | 09:35 PM
JAFAW's Avatar
"It has a different computer design somehow to prevent the heat cycle problems."
Does the top of the pump have cooling fins? What is different about the computer to solve the problems?
Old Jul 12, 2005 | 12:45 PM
Muted User
for any of you who are interested Blue Chip doesnot make a hot rod pump, scheid does make one that gives you 40hp, Industrial Injection makes one also which gives you 80hp. Scheids pump is $1782 and Industrial's pump is $1600.
mopar440cu
Nov 28, 2012 10:33 PM
DieselRebel24
Dec 4, 2010 03:22 PM
Erska
17
Mar 6, 2009 09:52 PM
Smokin'02
Feb 25, 2007 08:39 PM
Timmay2
25
Feb 12, 2006 01:00 AM
