new injector and no start
Old Jul 18, 2008 | 09:42 PM
jaredctd's Avatar
i just put in some new injectors and now the truck won't start.
Old Jul 18, 2008 | 09:53 PM
scottsjeeprolet's Avatar
You'll need some help with this.
Crack the 1,2 & 4 injector lines. Have someone crank the engine for no more than 30 seconds at a time until fuel comes out. The engine should try to start, if it does then turn it off and tighten the lines back up.
Old Jul 18, 2008 | 09:54 PM
BigIron70's Avatar
Cummins Guru
What year is your truck?
Old Jul 19, 2008 | 09:29 AM
jaredctd's Avatar
its a 98.5. I got it started and now it's idling very bad and when i put it into gear it bogs way down with a dead pedal. I pulled codes and got a p0216
Old Jul 19, 2008 | 09:43 AM
nickg's Avatar
did you install complete injectors or nozzles? and what type ? from what I've read a 0216 can be caused by air in the fuel, so it is possible to have a bad injector causing your poor performance, and the code could be an old history or whatever.
...or it was time for your VP to give up the ghost.
you could try cracking the line at each injector while its running to see which cylinder is not firing (engine rpm will not change when you find the bad injector)
Old Jul 19, 2008 | 09:50 AM
jaredctd's Avatar
I have not done that yet, it got too dark last night. Still drinking coffee this morning. But i just got those injectors from gus over there at farm boys diesel, so I know those are all good. That air would work out after running for a while, I need to do that too, my neibors weren't so happy last night. I'm wondering if it's the cross tubes.?
Old Jul 19, 2008 | 10:37 AM
graphitecumnz's Avatar
0216 is the injection pump death code...
once you've gotten the truck started and idling, put a wrench on the lines and make sure they're tight... a loose line will cause a funky idle and if the truck sits long enough, hard starts.
Old Jul 19, 2008 | 10:03 PM
wurkenman's Avatar
After I changed my nozzles, it took about a minute or so for the truck to settle down on the idle. I hope its not the IP, that would suck, I know
Old Jul 20, 2008 | 11:04 AM
jaredctd's Avatar
It turns out my engine serial number used one time use crossover tubes so they are leaking, I'll get some new ones on monday. Thanks for the replies.
quads4_life
May 1, 2010 12:54 PM
4969joes
Mar 18, 2010 10:19 AM
CoolumConst
Oct 11, 2008 10:00 PM
roberts11260
17
Feb 9, 2007 01:03 PM
gablekevin
Sep 19, 2006 12:12 AM
