New to code reading
Old May 14, 2006 | 07:09 PM
TxnBorn88's Avatar
New to code reading
i just bought a 2001 ctd 3500 dually 6 speed and when i went to check the codes P ECU came up then it went blank the it said P DONE is that normal what does that mean
thanks for the help
Old May 14, 2006 | 07:12 PM
nitrousn's Avatar
No stored codes.
Old May 14, 2006 | 07:42 PM
phox_mulder's Avatar
Actually it should have said:
P PCU
P Done
P ECU
P Done
(or the other way around, I can never remember if it does the PCM or the ECM first)
No codes, if there were, they would have flashed after the PCU but before Done, then after the ECU but before Done.
If sometime down the road you see a P-1693 and nothing else, it means you have a code but it isn't readable by the key on/off method, it needs to be scanned by the DRB Scantool at the Dodge Dealership.
phox
Old May 14, 2006 | 07:50 PM
greasemonki's Avatar
http://www.obdii.com/
for when you do have a code, this will let you look it up and know what it means
Old May 14, 2006 | 10:58 PM
TxnBorn88's Avatar
Alright guys thanks alot for yalls help
dkenny
Jun 19, 2014 12:41 AM
mullishacrew
Mar 18, 2012 12:41 PM
bankspwrdodge
May 1, 2007 08:15 AM
bankspwrdodge
Apr 30, 2007 10:19 PM
STEERJOCKY
Apr 22, 2007 12:32 PM
