New code for me (P0237)
Old Oct 8, 2007 | 03:52 PM
PChouinard's Avatar
My book says Map sensor voltage too low. Is this typically a sensor problem? Will my edge ez plugged into the map sensor make a difference? I think I'll disconnect the ez, drive the truck, then check for code again and keep an eye on your all's responses..
Old Oct 8, 2007 | 04:23 PM
hamilton71801's Avatar
I was getting that code and replaced my map sensor with no change. I eventually took off my boost fooler and it went away. Funny thing, I could still hit 28 psi of boost and not throw a code so I guess the fooler isn't needed unless you're pushing some serious boost.
Old Oct 8, 2007 | 04:35 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Sounds to me like a MAP sensor going south or maybe it just needs a cleaning. Also check the MAP sensor plug. I'd clean it well and ad dielectric grease before re-plugging.
Old Oct 8, 2007 | 04:50 PM
need12v's Avatar
Hurts nothing, that code shows up if you disconnect the MAP for more smoke...
Old Oct 8, 2007 | 05:02 PM
JPR Ram's Avatar
Only if you have an Edge Comp, maybe there is a few others also. If stock tho, the ECM will put you into a limp mode; as with most other performance boxes such as some Quadzilla's or Banks or Edge Juice and I beleive Edge Ez.
Old Oct 8, 2007 | 05:09 PM
PChouinard's Avatar
I think this happened to me leaving a stop light. The truck didn't respond well and it took a few seconds to get going. That's when the "check engine" light came on. At first I thought my time had run out with the P0216 code (I've had that for over a year now). I drove the truck a little while ago and all is normal. Perhaps just a hiccup I guess. I'll dig in and look at some connectors tommorow when it's cool... Thanks for the tips and keep 'em coming if you have another idea....
Old Oct 9, 2007 | 10:55 AM
PaulDaisy's Avatar
With my luck, the VP would quit not in my driveway but when I am 200 miles away in the mountains, in the middle of a shelf road. So, when I saw the 0216 I decided it was enough of a hint and replaced the injection pump.
-P
Old Jun 2, 2008 | 09:21 PM
PChouinard's Avatar
Time to dig up a fossil here.. I was towing my camp trailer this weekend and I could barely make 6% grades at 40-45 mph. On the way up the hills the engine would go flat, I assume it was defueling, and then rev back up but I had no power. On the way down today, I stopped and unplugged my ez, removed my p0237 and p0216 codes and carried on. I barely made it up the next 6% and I was right on the right line of the temp guage and doing 35 mph.
On a side note, while I was unhooking my ez, I noticed smoke puffing out of the breather hose where the puke bottle used to be. I don't recall seeing that before..
Is it time for a new VP?
AllonBlack
Sep 11, 2007 11:56 PM
2 busy
Aug 19, 2007 09:48 AM
REDNECK-WELDING
Apr 26, 2007 04:59 PM
MOJO1
Oct 27, 2006 01:09 PM
JDGPULLER
May 27, 2006 02:20 PM
