New Clutch
Old Aug 17, 2004 | 09:41 AM
Brad Gray's Avatar
New Clutch
My Clutch is slowly going and i'm in need of some help. My Truck : Ram 2500 6 speed diesel, guages, power edge comp and open exhaust. I do some pulling of Tractors and Equiptment. Please give me some contact Info and suggestions/prices on clutch replacment. If anyone lives in KY close to Fleming Co. and wants to help let me know.
Old Aug 17, 2004 | 02:46 PM
Haulin_in_Dixie's Avatar
Give Peter at South Bend Clutch a call. If you cannot afford that you might try a LUK ProGold, which is a bit stronger than the stock and can be obtained from a parts house.
By far the smoothest, best pulling clutch is the SBC if you are working it hard.
Old Aug 18, 2004 | 10:56 PM
OldSmokey's Avatar
I read a while back that the LUK clutches were good. Here is a site. http://www.carolinaclutch.com/6%20speed%20dodge.htm. They are cheaper then the SB. On the other side SB has worked great for many people including me. Im sure someone will have some more info.
Old Aug 19, 2004 | 02:30 PM
Saxet Nomad's Avatar
Quite happy with my SBC clutch!! Can't believe the extra HP that you put to the ground with a clutch that doesn't slip!
Old Sep 8, 2004 | 03:32 AM
Barry Smith's Avatar
I tried to save some money on a clutch and bought one that said it would hold 1000 ft/lb. it would, BUT when you let off the clutch loaded it would chatter your teeth out and almost bounce the front tires off the ground. I finally broke down and bought a SBC and have never been more happy with a clutch. H.I.D tried to tell me to go with a SBC an I didn't listen and it cost me an extra $500 or so. Go with the SBC and you won't be disappointed.
Barry
Old Sep 8, 2004 | 03:42 AM
HOHN's Avatar
Unless you're shooting for huge HP, the South Bend OFE is the clutch of choice. Many consider it THE towing clutch.
RustyJC has one in his truck and tows a large house on wheels. He says it's very smooth, with pedal effort like stock. It is a little more grabby at low speed (when hitching up), but it's not drastic.
I'll probably go SBC when I do it. I'll match the clutch to my HP-- OFE if I stay where I'm at, or FE if I go for more HP.
Old Sep 8, 2004 | 07:40 AM
RustyJC's Avatar
As Justin says, the Con OFE is slightly more aggressive on engagement than the stock clutch. It wants to chatter if you're slipping it at idle to maneuver the RV into a site or into its covered storage bay. The solution is to bring the RPM up to about 900 or so, then slip the clutch to get moving. The OFE doesn't mind this and in fact is smoother with higher relative speeds between the flywheel/pressure plate and clutch disc.
The Con O would probably be about as smooth as stock if you wouldn't overpower it. The OFE is probably about as good a compromise as you can get between holding power and "good manners".
Rusty
Old Sep 10, 2004 | 10:40 AM
K2Cummins's Avatar
I just got my SB Con OFE and I absolutely love it. It feels almost like the stock clutch and is holding my power very nicely. I just did my first tow with it and it was great; no problems what so ever with 15K behind me. As Rusty said it seems to be the best when it comes to holding and manners.
Derek Crowl
Aug 20, 2013 10:43 PM
hot_runner58
Dec 7, 2010 02:34 PM
Backwoods Bumpers
Nov 20, 2007 08:01 AM
WACTD
Jul 25, 2006 11:41 AM
mbmrang
Jan 21, 2006 12:49 PM
