Need your adice-Tire shop broke tierod sleeve
Old Apr 29, 2011 | 10:00 AM
OUTDOORSMAN's Avatar
I stopped in my local tire shop to get a nail hole pugged. I bought the tires from them. Patches, plugs and rotation are free with purchase.
The shop guy repairs the tire and rotates the tires. I tip him and hop in my truck to leave. I back out and pull into 4 lanes of traffic, the first lane is the only one available. The truck wont steer right. IT WONT TURN RIGHT. I cant believe it. A semi and other cars coming at me at 55mph and I cant turn and I am going to get hit if I dont take evasive action. As soon as I can I floor it, cross 4 lanes of traffic and end up on the median.
upon inspection I see the sleeve on the tierod end and tierod bar is bent up with a fresh break and the bolts are locking up on the spring mount on the axle on a right hand turn. It looks like the jack slipped from the axle and caught the tierod sleeve.
Called AAA got a tow home and replaced the tie rod end and sleeve. now I have what I can descibe as a clunk when I turn the wheel side to side. I can feel dead space and then a catch and the tires turn. Kinda hard to descibe.
Could I have broken the steering gear box? I had my neighbor turn the wheel back and forth and I was under the front end. I could see the play in the steering box before it moved the arm and can hear a kind of clunk.
Thanks for any thoughts. The tire shop accepted responsibilty. Said they would pay for parts and labor.
Old Apr 29, 2011 | 12:19 PM
Since my post I took the truck in and they found the problem. Bad track bar. We suspect it is just worn out. I guess I will be looking for a replacement.
Suggestions on that? lol I will do a search here. I know it has been talked about.
Mods feel free to delete if you like.
Old Apr 29, 2011 | 01:18 PM
torquefan's Avatar
Glad it has ended "fairly" well. Regarding the track bar, it depends how much you want to spend. Best bang for the buck is a jobber replacement from Moog. Bigger ball/socket and stronger than OEM. there are also several "specialty" track bar setups out there if you want to spend more.
Old Apr 29, 2011 | 02:01 PM
nkennedy's Avatar
If it's a 4x4 I'd go with one of the specialty pieces, but id 2WD I'd go with the Moog.
Old Apr 30, 2011 | 01:20 PM
Junk Man's Avatar
Fix it once - Thuren. Give Don a call & make sure what is needed for your truck.
afoulk
Mar 10, 2011 04:15 PM
cookster
Dec 4, 2008 07:44 PM
ddestruel
Jun 5, 2007 07:11 PM
Boondock
Apr 29, 2005 06:08 PM
