Need some trouble code help
Old Mar 5, 2006 | 03:06 PM
sammy340's Avatar
Ok, i hooked up a scanner to my truck after getting the check engine light to repeatily come on after taking the negatives off the battery for a reset.
I ended up getting two codes........
P0121...APPS and idle validation disagree
P0230...Transfer pump ckt out of range
Can someone tell what the problem may be?
What happens is that every once in awhile i totally lose power for about 3 seconds then it kicks back on. Seems to happen at lower RPM..
Thanks
Jeff
Old Mar 5, 2006 | 05:49 PM
sammy340's Avatar
Is the transfer pump the lift pump?
Old Mar 5, 2006 | 05:56 PM
phox_mulder's Avatar
Yes, Transfer Pump = Lift Pump.
Could be a dying lift pump, or a dying APPS, or both.
phox
Old Mar 5, 2006 | 06:03 PM
sammy340's Avatar
What exactly is a APPS? Is it easy to fix?
Does it somehow sense Lift pump pressure and thats why it's sending me that trouble code?
thanks
jeff
Old Mar 5, 2006 | 06:08 PM
No, they are seperate entitites.
Accelerator
Pedal
Position
Sensor
Fly by wire system, no physical connection between the skinny pedal and the injection pump,
APPS tells the computer how far you've pushed the pedal, computer tells the injection pump how much fuel to spray,
$300-$350 bucks to replace.
Lift pump, $150-$200 to replace.
Fuel pressure guage will let you know the health of the lift pump.
phox
Old Mar 5, 2006 | 06:17 PM
sammy340's Avatar
Phox
Are you saying that it could be a wiring problem or just that it is a bad wiring job from the factory?
Thanks
Jeff
Old Mar 5, 2006 | 06:19 PM
No, not saying that at all.
Do a search here for "lift pump" and/or "APPS" for more explanation.
phox
Old Mar 5, 2006 | 06:22 PM
sammy340's Avatar
Phox
I just looked at the tech facts..maybe i should try the APPS reset procedure. That might do the trick i hope.
THANKS for the help
Jeff
spye
Oct 29, 2007 08:09 PM
SilverRam01
Jul 30, 2005 06:53 AM
BUZZB8Z
Apr 20, 2005 09:42 AM
