Need New Lift Pump
Need New Lift Pump
I am in need of a new lift pump just found out the guy that done the work on my tranny also replaced the Injector pump but not the Lift pump that probably caused the pump. Also would this be what makes my truck idle up and down when I start. Thanks Again
PN 4090046 is the campaign lp $65 from your cummins dealer . PN3990105 is the stock lp $156 from cummins . Id get the campaign pump. I here its the same, maybe beter and less dough$$
Idle up and down at start might be the warm up cycle
How do you know the lift pump is bad?
If you want to stay with 3/8" lines, go with the Geno's relocation kit. I found a campaign pump but it crapped out at 30k. Then I went with the Aeromotive 11203. Runs 16psi at idle, 12-13 at 65 and WOT never below 8. Have 25k on it with no problems at all. You can find it at speed shops or Summitt Racing.
Just my 2 cents
Q
Just my 2 cents
Q
camerd18
Aug 21, 2008 07:20 PM
89dieselkong
Dec 18, 2007 11:38 PM
adgr71
Nov 28, 2005 07:34 PM
