Need help with my transfer case issues
Old Apr 22, 2010 | 07:58 AM
DodgeRamdiese01's Avatar
Hi all my issue is a friend of mine was supposed to buy the 2500 which he never paid for so I repossessed it a couple of monthes ago. while he had it he put the truck in low range to get unstuck, and it wouldn't come out, finally after yanking on it it finally moved into 2 wheel,
now i have the truck back and I have been trying to figure it out it goes into 4 wheels drive but if you're not carefull it will easily go past 2 wheel and neutral into low range, problem is it doesn't engage low range at all the light comes on and the lever moves like 10 inches forward it just seems like there is some bigger issues, it doesn't seem to go into neutral to unlock the case at all either
also on a possible related note it feels like I have both rear wheel locked into the 4 wheel drive portion as when I turn at slow speeds it feels like the rear tires are fighting each other (if that makes any sense), now I dont need 4WD at the moment but will in the winter as I will be plowing so I may need low range at some point aslo
any help would be appreciated thanks
Old Apr 22, 2010 | 09:55 AM
Copenhagenjunkie's Avatar
Range fork is worn out or linkage is out of adjustment.
Differential fluid change and add friction modifier for track-lok/power-lok diff.
Old Apr 22, 2010 | 12:30 PM
I will check Will bet on the linkage being out of ajustment, I dont use the 4WD very often so i am wondering how i would wear out the fork any ideas? maybe just age. will do the fluids ASAP thanks for the suggestions
Old May 2, 2010 | 07:22 PM
JSPulliam21's Avatar
The fork gets worn any time the tires are rolling. The plastic pads are what wears, and they can be replaced easily. Just gotta split the case & get a decent set of retaining ring pliers.
Old May 2, 2010 | 07:44 PM
Makes sense didn't check into this yet as I am in the middle of of ripping out a v8 and putting it in my plow truck
dukektm
Sep 5, 2012 01:07 AM
DODGER BOMBER
Aug 22, 2009 04:06 PM
tool
Jan 14, 2008 03:07 PM
BAJA MAN
Jun 16, 2005 10:17 PM
