NAPA air filters
Old Dec 15, 2005 | 08:01 AM
Mopardan's Avatar
NAPA air filters
I did a search and could not find a positive answer. I'm changing my oil today and need to change my air filter too. My air filter has about 38k original miles on it (ya I know) I don't want to drive 100 miles round trip to the Cummins store, sooooo is the napa replacement filter ok?
Old Dec 15, 2005 | 08:19 AM
MnTom's Avatar
Why not just get a BHAF? They are not that much more than the stocker and they last longer. Here is a list of part numbers:
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
AFE 20-40044
Carquest 87790
John Deere pmah19037
Big A 93790
Caterpillar 3i0005
Fleetrite ahr819037
Luber-finer laf2531
Fram ca6818
UNI 908
Tom
Old Dec 15, 2005 | 08:25 AM
Geico266's Avatar
I order mine on line and have a couple extra ready to go. It's a good idea to have a few extra fuel filters around as they can plug up with bad fuel. I'd leave the old one in and buy a stock of fliters.
http://www.scheiddiesel.com/index.htm
Old Dec 15, 2005 | 12:58 PM
swmnkdinthervr's Avatar
None of the above numbers would come up on the NAPA site...and I can't find a listing for fuel filter at Scheid...this can be frustrating...where do most of you buy at?
Old Dec 15, 2005 | 01:15 PM
P.J's Avatar
P.J
The 2790 should? Its a Duralite sold at NAPA.
Old Dec 15, 2005 | 02:07 PM
TallTom's Avatar
filters
Order the sets Fuel / oil and air from www.genosgarage.com can't beat the price and they will get delivered to your door.
Fleetguard is all I use.
Tom
Old Dec 15, 2005 | 07:51 PM
TNutcher's Avatar
I use NAPA for everything, fuel, oil, BHAF pre fuel filter for lp ext.... Yes buy a good stock of filters so theres no need to go back to NAPA too much
TNutcher
Old Dec 15, 2005 | 08:34 PM
Mopar1973man's Avatar
Tom
This is the best way to go... You don't have to worry about greasing the gasket and having dirt leak pass the seal on the stock air box... So far I figure I will replace my BHAF filter about every 50K-75K miles. Compared to every 30K on the stock filter... The BHAF is about 3X bigger than stock elements...
Old Dec 15, 2005 | 10:41 PM
piperca's Avatar
Wix makes the filters for Napa. All I use is Wix, great filters! Not to mention, you can pick them up real cheap at http://www.fleetfilter.com/index.html
Oh, by the way, the Wix 42790 BHAF is only $29.41!
Old Dec 15, 2005 | 11:06 PM
Mopardan's Avatar
I bought and installed a NAPA Gold filter today, part #2846. Will see how it does. Thanks for your help.
Old Dec 16, 2005 | 05:25 AM
Is there a pic someplace or a suggested way to install that filter...?
Old Dec 16, 2005 | 07:49 AM
surfram's Avatar
I have been running the Napa Gold 2846 air filters. I left the last one in for 20,000 and the filter minder never moved. According to that web site, it only flows 5 cfm less than the 42790 BAHF. 675 cfm vs. 680 cfm. They cost $30 at my local Napa. I will be ordering a few from fleetfilter.
Old Dec 16, 2005 | 07:53 AM
MnTom's Avatar
It is so simple you won't believe. Pull the stock airbox out and put the neck of the filter in the tube going to the turbo. Tighten the clamp and you are done. It is that simple.
Old Dec 16, 2005 | 08:14 AM
Picture says a thousand words...
Here you go my setup with the BHAF and the heat shield that DTR supplies the pattern for...
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Dec 16, 2005 | 12:08 PM
Thanks a bunch...just what I was looking for!!!
