motor dies when turning on lights
Hope this helps
mine was a bad ground in a factory splice. It was located in the frame behind the fuel tank. It grounded the fuel pump and the rear light. Check the wiring from the fuel pump if you pull off the rear tire it gives you some more room. I had to pull the bed off to fix the splice and put a separate ground for the fuel pump. But that is what fixed mine. Hope that helps, email me if you have any questions. Good luck!
You can pull the fuses for the tail lights brake lights and running lights it'll narrow it down for you.
vintovka
04-30-2012 12:38 PM
ETS 76
03-28-2011 07:06 PM
JARHEAD
19
04-01-2008 11:34 AM
Palmetto_kid
03-31-2005 02:01 PM
