missing and stumbling above 2300 rpm
when the engine is brought above 2300 rpms it stumbles like it is missing and won't rev over 2500 rpm. this is while driving. '99 3500 6 spd 4x4.
ps i replaced the crank postion sencer a week ago, but still get codes no cel
updated info
ok, just after i bought the truck the CEL or MIL came on. had autozone check codes (PO336, PO234, PO236). bought a scaner and replaced crank sensor, cleared codes. problem solved, so i thought. i'm still getting the (PO234, PO236) codes. what is the posible cause of these codes and are they related to my first post?
If you dont want to spend $$$ on an in-cab gauge get a mechanical gauge from Harbor Freight or something. Gotta be fuel pressure causing it. Change the fuel filter and see if its still going on. Is the P0236 the VP44?? Can't remember.
SeanB23
Apr 5, 2010 07:35 PM
chadpatten
27
Nov 30, 2005 10:31 AM
