Miss at idle???????
Old Jul 16, 2008 | 02:49 PM
busa's Avatar
Miss at idle???????
My truck has developed a small miss at idle. It feels like when you get a missfire on a gasoline engine such as when the distributor gets wet or a plug wire isn't on all the way. The truck runs great under load or at cruise. All the filters are new, fuel pressure won't budge from 15psi, no codes and I know it dosn't matter but the VP is only 2 years old. No changes were made, the miss just started one day. Any you guys run into this before? Its not causing the truck to stall or even come close but it is bugging me. Thanks for any ideas.
Old Jul 16, 2008 | 02:52 PM
BigIron70's Avatar
Cummins Guru
I would do a valve adjust if over 100k miles on truck, then try a diesel injection additive. Could be just soot buildup on injector tips.
Old Jul 16, 2008 | 03:01 PM
busa's Avatar
Adjusted the valves two months ago and have been running additive since I bought the truck. I don't think its soot build-up, just got back from a trip through the mountains pulling, the EGT's were up for a while so the combustion chambers should be relativly clean, but what do I know.
Old Jul 16, 2008 | 03:36 PM
Big Green11's Avatar
I have the same problem, and my friend with a 500hp '01 does sometimes. although im not sure of my last valve adjustment and ive got a few miles on 'er
Old Jul 17, 2008 | 02:08 AM
Diesel Doc's Avatar
same problem here. it only happens when it is at operating temp and it is random. it wont do it for a week then it does it everytime I go to idle for a while then it goes away again. I have changed everything short of the ecm and it still does it.
Do a search. you are not alone.
Old Jul 24, 2009 | 12:18 PM
Johnny0874's Avatar
My 94 12v has a lot of ticking in the valve train when I go too far bewteen oil changes... I change my oil every 5k with 50/50 lucas and rotella... If I start to hear excessive noise, I know it's time to change the oil (even if I'm not at the 5k marker yet). I don't know if this will fix anyone else's issues, but it works for me. My old beater has just under 260k miles on it and it runs like a champ. Of course I havn't "cranked it up, all I've added to date is the exhaust and the K&N drop in filter) " and I seldom drive faster than 65 or 70 so that may have a lot to do with it (most of the speed limits around my house are 45 - 60).
I'm going to do a valve adjustment this weekend... if anyone is interested I can let you knwo if my milage jumps up a mpg or so... It usually does when I do this.
I adjust my valves every year... they don't need much adjusting... the number 1 and number 6 valves (not always the same one but always those 2 cylinders) for some reason are always out by a mill in the strectched direction (ie the valve clearance has to back off a bit)... wonder if there is a service bulletin about this???
Johnny
Old Jul 24, 2009 | 01:09 PM
rholbus's Avatar
mine would do it when i was running diesel kleen
gonehuntin
Mar 13, 2006 12:28 PM
NJMurvin
Jul 15, 2004 11:28 PM
NOTSTK
Apr 22, 2004 10:58 PM
fish01
Apr 21, 2004 12:15 PM
tbourque
Feb 19, 2004 12:57 PM
