Mess of a fuel system.....
Old Jan 26, 2012 | 01:13 AM
Dodge Diehard's Avatar
Exclamation Mess of a fuel system.....
Ok so i recently bought my first cummins. An 02 thats still pretty basic and here is problem number one i wanna knock out. Whoever owned this truck was a little off in the whatever progression they wanted to make and ended up with the factory lift pump, an in tank pump, an air dog 150 gph pump, and some cheap in-line pump in front (closer to the engine) of the airdog. they bypassed the entire main fuel sytem according to the code it was throwing and while the fuel line still went thru the airdog and the junk one in front of it, the power wires werent connected and there is barely fuel pressure. any suggestions on a clean place to start would be great. Anyone that wants to help with more of the issues let me know
Old Jan 26, 2012 | 06:53 AM
dkenny's Avatar
remove everything in the fuel system except the AirDog..
drop the tank remove the in tank pump..too
then install a fuel pressure gauge. and low pressure idiot light won't hurt either
-dkenny
Old Jan 26, 2012 | 08:05 AM
patdaly's Avatar
You mean more isn't better??????????????
Old Jan 26, 2012 | 08:26 AM
Its already got the gauge tower on it but im pretty sure the pyrometer sensor wire is burnt up and the fuel pressure gauge if its hooked up right? only reads two lbs and i think the airdogg is burnt up
Old Jan 26, 2012 | 03:26 PM
Sea:\>Drive's Avatar
You won't know for sure until that is the only pump running everything. The others that have failed may be restrictions. Pick the AirDog - get rid of everything else - then if you find you still only have 2lbs of pressure get a hold of AirDog and they'll assist you with fixing it up or replacing it. If it is really old it may not have their current lifetime warranty -but they'll still work with you to get a new one at a good price.
Old Jan 26, 2012 | 07:12 PM
dkenny's Avatar
more can be better if they are in parallel..
not series..
are you sure the AD is bad??you might be only seeing 2 psi because of the other pumps/filters..
you also might need new AD filters..
-dkenny
mr. ed
15
Feb 22, 2009 04:08 PM
dodge_kid9712
Jan 10, 2008 05:59 AM
tmiller24
Mar 9, 2003 08:35 AM
BigBlue
Feb 5, 2003 06:36 PM
