MAP SENSOR QUESTION
Old Sep 26, 2003 | 07:41 PM
427AC's Avatar
MAP SENSOR QUESTION
I HAD A POOR EXPERIENCE TOWING BETWEEN 4 AND 5000LBS. I COULD NOT EXCEED 65MPH ON ANY HILL. I RAN A SCAN WITH OBD2 AND NOTHING CAME UP. DOES THE OBD2 READ ANY BOOST ISSUES? I ALSO READ A THREAD ON THIS WEBSITE ABOUT AN ADJUSTABLE PRESSURE REGULATOR BEFORE THE BOOST SENSOR. WHERE IS THE BOOST SENSOR LOCATED AND WHERE CAN I GET THE PARTS TO MAKE THIS CHANGE?
Old Sep 26, 2003 | 11:18 PM
NitroBird's Avatar
Re:MAP SENSOR QUESTION
Sounds like you need an EDGE box end boost elbow then you won't have that problem anymore ;D
Mike
Old Sep 27, 2003 | 07:47 AM
PourinDiesel's Avatar
WHAT YEAR IS YOUR TRUCK? IS IT MODIFIED?
Old Sep 27, 2003 | 09:13 AM
427AC's Avatar
the truck is a 99 with AT. bone stock with the exception of a BHAF. 65000Miles. Just changed the fuel filter and air filter
Old Sep 27, 2003 | 12:00 PM
StakeMan's Avatar
Does it have gauges? If so what where the max readings when towing those loads?
Old Sep 27, 2003 | 03:40 PM
427AC's Avatar
NOR GAUGES YET. I AM IN THE PROCESS OF SHOPING FOR THEM NOW. I CHECKED THE IAT THIS MORNING AND IT WAS AS CLEAN AS CAN BE. I AM ALSO GOING TO HAVE THE LIFT PUMP LOOKED AT THIS WEEK SINCE IT IS STLL UNDER WARANTY.
DO YO KNOW ANYTHING ABOUT THE ADJUSTABLE PRESSURE GAUGE AS A WAY TO FOOL THE BOOST SENSOR? AND WHERE IS THIS SENSOR?
Old Sep 27, 2003 | 09:54 PM
427AC's Avatar
[quote author=StakeMan link=board=4;threadid=20206;start=0#msg189999 date=1064682054]
[/quote] I SEE THAT YO ARE IN THE DENVER AREA. I TOWED THIS LOAD TO PPIR AND HAD TROUBLE WITH THE NORTH SIDE OF MONUMENT HILL. ASLO HAD TROUBLE ON C-470 NEAR BANDEMERE SPEEDWAY. STILL HAS ME BAFFLED.
scottboy69358
Jul 4, 2013 02:05 AM
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
Booost Almighty
Jan 1, 2006 01:41 PM
