Luke's Link
Old Apr 6, 2006 | 09:15 PM
Silverjay's Avatar
Luke's Link
A couple of questions before I put my link on this weekend. The instructions seem to indicate that the three metal shims are not installed from the get go, just hold on to them to adjust later. Correct? When the joint loosens up later and I have to shim it, how much do you add? The original setup required the joint to be off, do you have to pull it again or can you measure something in place?
Old Apr 7, 2006 | 12:15 AM
Cageman's Avatar
When I installed mine all the parts went in place. So when you say shims do you mean the washers? Its been awhile but all 3 washers and the spring go in place there were no extra parts. The only way it will loosen is if the spring should soften then to adjust you just tighten the cap in more. I can look for the instructions I think the pic shows it in the order it go's in..
Old Apr 7, 2006 | 07:36 AM
V Baker's Avatar
You don't remove the ball to add shims,just remove the cotter pin and unscrew the plug. Good luck
Old Apr 7, 2006 | 07:58 AM
Silverjay's Avatar
How many shims do you add when it gets loose?
Old Apr 7, 2006 | 04:15 PM
Silverjay's Avatar
Just talked with L&L. They said not to install the three shim washers. If the joint ever loosens up to insall one washer and check for play. Repeat if needed to remove play.
wcbcruzer
13
Sep 4, 2006 03:39 PM
Flashpoint
Apr 15, 2006 07:59 PM
jfpointer
22
Mar 27, 2005 11:09 PM
Crimedog
Sep 21, 2004 10:13 PM
Palmetto_kid
Feb 17, 2004 06:07 PM
