LP Buzz
Old Oct 21, 2007 | 07:10 PM
RabidRam's Avatar
LP Buzz
My first post here, been reading and enjoying the info for quite awhile and now I need help
On the way home yesterday I noticed my fuel pressure dipped down to 4 (gage + red idiot light less than 5 psig) going around a corner then came back up to 14. I thought that was odd. My tank was low but still well above an 1/8th and no light. Today on the way to fuel it up down went the fuel pressure and it died. Got fuel and fired back up and now I notice no buzz when I turn the key on. It fires right up but takes what I think is a long time to build pressure, 2-3 seconds instead of popping right up to 14.
Weak LP and time to replace and/or do I have more issues. No check engine light
Thanks Scott
Old Oct 21, 2007 | 07:27 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Welcome to DTR.
Dodge Fuel Level Senders are notorious for leaving folks stranded with no fuel when the gauge still reads over 1/8 tank.
Try adding keeping the fuel level closer to 1/2 tank.
You might have air trapped in the gauge line.
It should work it's way out.
Keep an eye on the fuel pressure, the lift pumps have a baaaaaad reputation also.
Old Oct 21, 2007 | 07:42 PM
RabidRam's Avatar
Welcome to DTR.
Thanks. I know better to let the tank get that low but it was circumstance driven. I do not hear the fuel pump when I turn on the ignition and that is part of my question
Old Oct 21, 2007 | 09:49 PM
gunnie's Avatar
do you have a factory lift pump or have you changed to a frame mounted? does the fuel pressure gage move at all when you turn the key on? have you tried just bumping the starter without starting to let the pump run ?
Old Oct 22, 2007 | 05:56 AM
Shovelhead's Avatar
If you're seeing above zero pressure, then your lift pump is working.
Do you have a mechanical, or electrical FP gauge?
Diesel fitter
Feb 17, 2003 09:39 AM
Mopar_Mudder
Nov 27, 2002 05:11 PM
Buzz
14
Nov 24, 2002 09:36 PM
Buzz
Nov 19, 2002 07:02 AM
Buzz
Nov 18, 2002 10:08 PM
