lp
Old Feb 1, 2007 | 10:59 PM
johnh's Avatar
lp
how come my new campaign pump only puts out 10 psi at idle? (i installed two side by side on the frame to replace the two carter 7 psi pumps)
i had both 7 psi pumps running at the same time but i lost power to them, so i installed the campaign pumps in their place. i wired one with the factory plug..... if it fails , i just unplug it and plug the other one in.... i get the same pressure with both
Old Feb 2, 2007 | 09:09 AM
Ram1999's Avatar
I have the same pump, except just one, I get about 14 at idle.
Just wondering if having two hooked up is causing a restriction by having to pump through one that isn't running.
Try powering them both???
Old Feb 2, 2007 | 12:46 PM
the_fox_man4's Avatar
you know I didn't hear you say any thing about using any relays to turn the pumps on You shoud do that It will make a but of diffrence giving full battery power to the pump/pumps in your case. oh ya and it didn't want to admit it on here but I had my last campaign pump fail in less than 6 months, i finaly addmited it when the truck needed a tow home. thats when I installed a walbro pump.
Old Feb 2, 2007 | 01:56 PM
Doug_TX's Avatar
Might depend on how you have that plumbed. If you don't have some type of backflow prevention in place (if plumbed in parallel) it could be creating a problem. If you're pushing/pulling through one pump (plumbed in series) you have a big restriction in the system.
Old Feb 3, 2007 | 08:50 AM
johnh's Avatar
that is a distinct possibility, i think i'll power up the other one on the same circuit. with no relay.... will the ecu handle it?
Old Feb 7, 2007 | 10:06 AM
Barry St John's Avatar
Same story for me. The last two lift pumps I had were directly from cummins and neither would give me much more than 10 - 11 psi fresh out of the box. Walbro 392 solved the problem.
Old Feb 7, 2007 | 08:09 PM
RAFTEN's Avatar
That is all I have gotten out of the last two campaign pumps.
