Low RPM bucking
Old Jun 14, 2007 | 03:25 PM
Y2GREY's Avatar
Low RPM bucking
My 02 3500 has a buck or hiccup between 1200 and 1400 rpm
any thoughts?
Grey
Old Jun 15, 2007 | 01:05 AM
Jim Dynomite's Avatar
Do you have a stick or automatic?
Do you have a power chip in it? Sometimes the aggressive fueling curve will do this at low rpm.
Sometime when it is hot out and with the A/C on the Injection pump will do this also.
Fill out your signature, it will help a bunch if we knew what you have.
.........Jim
Old Jun 15, 2007 | 06:01 AM
Y2GREY's Avatar
Sorry,
it's an auto, no chip
Grey
Old Jun 15, 2007 | 10:06 AM
Y2GREY's Avatar
When it's cool out and or not running AC it does not hiccup. What would cause this?
thanks
Grey
Old Jun 15, 2007 | 10:15 AM
Dieselbuilder's Avatar
Do a code check see what comes up first.
Old Jun 15, 2007 | 10:26 AM
RowJ's Avatar
Y2GREY- Welcome to DTR!
You are lugging the motor, IMO. Either tranny will do this at 1200 rpm..... but especially Automatics. Probably goes away when you add a little throttle .....No?
The problem - overdrive is a very tall gear ratio(.68). Great on the interstate at 70+ mph but I don't use it below 50 mph with stock tires.... or below 60 mph with my present 315/75/16's.
I lock out OD around town ... truck drives better, putting engine in the power band, and higher RPM does not hurt mileage. Also reduces smoke, if/when your add a little HP.
RJ
Old Jun 15, 2007 | 10:48 AM
Y2GREY's Avatar
Yup, when I lockout the OD no issues at all, with the auto-OD and 3:55s I'm pretty tall
Austinstrab
Jun 20, 2015 11:59 AM
bakdoor
May 14, 2012 06:35 AM
JSPulliam21
16
Jul 28, 2007 09:50 AM
matt1969
Jun 13, 2007 06:50 PM
fishin fever
Feb 22, 2004 08:32 PM
