low gear
Old Jun 24, 2021 | 07:48 PM
reb357's Avatar
Angry low gear
just bought 2002 2500 diesel transmission changes gears when its in low gear,also no over drive
Old Jun 24, 2021 | 07:57 PM
The transmissions are designed to change gear from the factory.
Please explain the issue and the vehicle in question better.
Changes gear when in 1 or in low range with a 4x4 truck?
Auto truck, I assume?
Please more info on the truck and issue if you want the best advise.
Old Jun 24, 2021 | 08:05 PM
reb357's Avatar
ok truck 2002 ram 2500 automatic should the tranny change gears when you put it into low gear it shifts at about 8-10 miles per hour.thanks for any help'
Old Jun 25, 2021 | 02:10 PM
I repeat....
Low gear in the auto, as in First?
Or are you talking when your in D in the transmission and, using low gear in the T-case?
Old Jun 25, 2021 | 09:18 PM
reb357's Avatar
LOW gear in auto T/C in 2 wheel drive
Old Jun 26, 2021 | 10:28 AM
Are you sure the shifter lever on the steering column, is adjusted correctly?
I have seen many old trucks that have the shift indicator on the dash read different than what the transmission is in.
I.E a truck that says it is in 1 gear but actually is in 2 or D.
Not shifting in to OD, could be several issues.
Bad computer, bad wire plug in connection [or just not connected], bad sensor, transmission fluid too hot.
OrangeBlackHD
Jun 22, 2010 07:11 PM
mr. ed
32
May 31, 2007 05:20 PM
Erik
Jul 10, 2006 12:58 PM
djgaston
Competition / Pulls / OffRoad
Sep 10, 2005 10:54 PM
97CTD
Oct 10, 2002 10:11 PM
