lost clutch last night
Old Aug 11, 2005 | 09:09 AM
getblown5.9's Avatar
clutch has been fine, ive slipped it too much a couple times and got it hot to where it wouldnt grab...but for my power level it holds great.
last night pulling out of a parking lot i pushed the clutch in and hit the brakes and the truck kept pulling, i was able to pop the shifter out of 2nd into nuetral, and pushed the clutch in again and there was NO pedal pressure...its nothing there.
I can see no fluid leaking and the reservior is as full as can be. When pushing the pedal down i can hear air rushing somewhere around the firewall, near where the cylinder is located that is attached to the pedal.
im hoping its just a hydraulic issue, and not the clutch itself...anyone have any suggestions
Old Aug 11, 2005 | 09:32 AM
newriverSpecon's Avatar
Pilot Bearing. Either the neddles fell down between the plate/flywheel or they have bound on the input shaft. I would recommend going with an after market bearing/bushing. South Bend sells a kevlar one. Quad4x4 sells a couple of sealed ball bearing ones. All of them require the flywheel to be bored. I wish I had a local option to get one when I did my clutch. Now I am pulling my trans. out again ( fourth time, twice due to a bad from factory clutch) while I have the truck down anyway to replace it.
If you do it yourself and go with a bushing make sure the input shaft is smooth. It will just tear up the new one if not. This is not as critcal with the BB (why I choose it). The other option is to upgrade your input shaft and flywheel/clutch to use the 13" clutch. If you got the dollars.
Randy
Old Aug 11, 2005 | 09:43 AM
i already have a 13" flywheel with the 6speed...so should i just go ahead and order the new clutch and put it in while i have the tranny dropped?
Old Aug 11, 2005 | 09:55 AM
Your right, missied your trans. If you can afford it, Yes. I did that and got a bad clutch. I had not had any problems before. Don't go stock, there are several options that will start a debates. Look at your options, decide what things are important to you (quality vs. price, customer service, time you have to fix it), and then make your choice.
Randy
Old Aug 11, 2005 | 10:17 AM
unfortunately i wasnt expecting this and dont have alot saved up to go with a nice SBC...so i am gonna have to go with something a little cheaper, but something that will hold the power i am making currently.
that would be the LUK cermatallic kit, its under $600 bucks and yes i know all bout peter's customer service and wish i could get a SBC, but i will get the LUK for now, and save up to go a ll out with a SBC DD in the future.
that is unless i find out its something simple like a master cylinder/slave cylinder on the clutch pedal
Old Aug 11, 2005 | 10:32 AM
I had to do the same. Luk had some other option for the 5 speed. You might check a little for yours. ASK them questions. It was only after I had problems with the first OEM and was dealing directly with the distributer that I was told about the HD version (not the cermetalic). It is "rated" for 100 ' lbs over stock. They could have something for the 6 speed.
Not that I doubt any of the reasons people use for SB but the price vs. product seems out of range to me. If I was throwing $6-$10K a year in my truck it would not be an issue. But I don't have that money.
Randy
P.S. The HD version of mine was only $60 more the oem.
forwardho
Jun 16, 2012 10:56 AM
1STGENFARMBOY
Apr 5, 2010 12:25 PM
Tank_66
May 19, 2008 09:45 PM
WChambers
Sep 24, 2007 09:17 PM
GCSS
21
Jun 8, 2007 12:43 PM
