loss of throttle
Old Dec 11, 2003 | 02:12 PM
gunracer1's Avatar
loss of throttle
my friend has a truck at his shop, 2001 6 speed cab and chassie dually 125k. while driving down the road it just goes down to idle. it will come back, and it may run 3 miles and it may not do it or it might do it a couple times in a mile. any ideas? i have never heard of this, he checked out the foot feed and it seems to be working fine. so he is thinking the pump part of the fly by wire is going out. anyone heard of this before, it would be a shame to have to replace the pump for something like this.
Old Dec 11, 2003 | 02:57 PM
BarryG's Avatar
Re:loss of throttle
I would check the apps sensor and quite possibly the vp44. When my 44 went out it would go to idle but it would only do it under certain circumstances.
Old Dec 12, 2003 | 07:20 PM
jweir's Avatar
Re:loss of throttle
You might try calibrating the apps...
Jim
Old Dec 13, 2003 | 02:23 PM
thumper 549's Avatar
Re:loss of throttle
whats the fual preasure?
Old Dec 13, 2003 | 08:26 PM
AKDSLDOG's Avatar
Re:loss of throttle
I would say the VP44 is your problem. I just went throught this. You could try to recalibrate the apps. You might get lucky, other than that, new pump time.
Old Dec 13, 2003 | 10:21 PM
Scubasteve's Avatar
Re:loss of throttle
Had the same problem with my truck, it was usually show up under light throttle and the truck would fall to idle after letting off the pedal and hitting it twice all would be good again.
Ended up changing the APPS and that solved the problem.
Good Luck
Jason
RHC
Aug 12, 2019 03:32 PM
tntk9
Nov 20, 2012 07:09 PM
cbrxxtreme
24
Jul 17, 2008 03:30 PM
98Ram25004x4
13
May 22, 2006 08:02 PM
WVPANHANDLER
Nov 11, 2004 05:25 AM
