lockup slipping
Old Nov 21, 2011 | 08:27 PM
cowboykilla235's Avatar
lockup slipping
my truck is in my sig, but basically what is happening is while im going between 45-50 MPH it will lock-up, then unlock. it might do this once or 5-6 times... it dosent happen all the time also. i checked fluid (level surface, parking brake on, truck in netural, and it was at the very max of full!
does anyone know of any good repair shops near Placerville Ca?
i live out near Boise Id, but im out home for the holidays....
what could it possibly be, and will it hurt to wait to check anything out till i get back home over the weekend?
any ideas? im worried about being stranded out on the highway while i drive home...
Old Nov 21, 2011 | 10:31 PM
01ram3500's Avatar
Maybe try a BD APPS Noise Isolator. They go for around 25 bucks and are known for fixing this problem.
Old Nov 22, 2011 | 07:51 AM
j-fox's Avatar
Electrical noise, sometimes a bad ground at the battery.
Old Nov 22, 2011 | 08:02 PM
whiskers's Avatar
Alternator noise will do it also. I had the issue, did all the fixes, but what finally stopped it was a good cleaning of the alternator insides. It is a noise issue telling the converter to unlock momentarily. Real common on these. most mechanics, even the dealers will not know how to stop it. i know because my son is one and didn't have a clue. Found the answers right here!
Old Nov 23, 2011 | 01:41 AM
turfguy's Avatar
also have the TPS checked; notorious for having to hunt in & out of lockup. Had my 95 2wd do the same thing. A new Tps fixed it for me.
Old Nov 23, 2011 | 01:46 AM
turfguy's Avatar
oops just noticed I was on the 24v forum.... not sure if the TPS is the same as a 12 valve, but I'd look into it anyways
Old Nov 24, 2011 | 10:29 AM
Could it hurt if i drive the 8 hours back up to boise idaho?
Old Nov 24, 2011 | 06:24 PM
j-fox's Avatar
As it relocks many times it is glazing the converter clutch, so be careful if you choose to drive it.
Old Nov 25, 2011 | 06:27 AM
snowjoker's Avatar
You could just unplug the alternator for a while then stop and plug it back in to recharge the system... im guessing you could go a couple hours before you needed to recharge the batterys..
Old Nov 26, 2011 | 12:27 AM
Russ Roth's Avatar
I have had pretty good success with stopping mine doing that by just lifting the wires at the alternator up and away from it. Pretty easy to try, may work and costs nothing.
Old Nov 26, 2011 | 07:07 AM
olddodgetrucks's Avatar
Go to ATS website and do there rewire,no cost works a-1
Old Nov 29, 2011 | 06:54 PM
tspooner3's Avatar
There's an old post somewhere on this website that addresses the issue. Has to do with grounding out one of the wires in the TPS harness. Had the same problem with my 99 - factory couldn't fix it. Finally made the correction myself and it's been fine for many years now
Old Nov 30, 2011 | 10:24 AM
James Birdsong's Avatar
Lockup slipping
I had my "Banks" system tell me the samething this weekend while towing my 5th wheel. No OBD 11 code was shown, only the Bank's monitor. The alert finally went away. Forgive me for being old and dumb, but what does "apps" & "tps" stand for. It might repair my problem as well. (don't mean to steal your thread). Thanks.
Old Nov 30, 2011 | 01:27 PM
turfguy's Avatar
I have looked all over the ATS website & can't find it as a product OR a pdf file. Does anyone have a link to it???
Old Nov 30, 2011 | 06:03 PM
Busboy's Avatar
Originally Posted by James Birdsong
what does "apps" & "tps" stand for. .
APPS = accelerator pedal position sensor.
TPS = Throttle position sensor
Both the same thing telling the ECM where the pedal is with an electric signal.
