Lo ngest running VP44???
#62
Administrator / Scooter Bum
The round part of the breather that the dump hose connects to unscrews from the timing cover giving you access to the 27mm nut.
After removing the drain hose, I just stuck a 3/8 extension in the hole and used it for leverage to unscrew the breather cover.
#68
Originally Posted by DTE
I have 374,000 on mine. i've replaced the lift pump 4 times but still on the original vp44.
Tell us more about your rig and what are you using for fuel.
Congrats man!
#70
#73
when they replaced my VP in '03 under warranty, the new one had a sticker on it that said REBUILT or something like that. The sticker is still there, but it's kind of hard to see unkless you look hard because it's under the apps ....sort of.
#74
Originally Posted by Fat Tom
Is there any way to tell if my truck is still on its original VP or not?
#75
probably more luck than anything. actually ran out of fuel just after i bought it. fuel gauge is not exactly accurate. 1/8 = empty. always use Howes Lubricator. one 1/2 gallon bottle will last me about 8 tankfulls. the truck has been very dependable. engine has had the valves lashed once, numerous lift pumps, and and booster seal. clutch slave/master a couple of times. worst problem has been the entire steering system. if you could keep it tight I would still be towing with it every week instead of the new one
