Limp mode problem has me confused
Old Mar 9, 2013 | 05:13 PM
jeeptjstud's Avatar
limp mode started intermittently about 6 months ago on my 98.5 24v with an edge comp box. Assumed it to be the MAP sensor so I just unplugged the MAP sensor. Driven it this way for about 6 months with no issues.
This last week it has gone back into limp mode. The difference now is that in blows black smoke and gets up to 3-5psi boost. 'if I hammer down the throttle it will cut off the boost and blow smoke.
I have cleaned all the connector point from the comp to engine. When I plug the MAP sensor back in it still is in limp mode, without all the smoke.
any ideas?
Old Mar 9, 2013 | 05:18 PM
Dieselbuilder's Avatar
sounds like the pump going south have you checked for codes?
Old Mar 9, 2013 | 08:16 PM
jeeptjstud's Avatar
codes from autozone
P1693-Tachometer circuit failure
P0237-Map sensor too high for too long
P0237-MAP sensor voltage too low
P0238-MAP sensor voltage too high
Old Mar 10, 2013 | 10:26 AM
rickf's Avatar
Have you tried replacing the MAP sensor? Use a GOOD one from Dodge or Cummins.
Also take the Edge out of the system until you find the problem, It could very well be the Edge that is causing it.
tj97dodge
Jan 14, 2006 01:55 PM
swimmy
Dec 3, 2005 09:52 PM
OldSmokey
Mar 26, 2005 06:53 PM
arctic426
Feb 28, 2004 06:22 AM
danlit
14
Jan 20, 2003 06:55 AM
