Limp mode & code #0606
Old Nov 11, 2010 | 08:04 PM
Twogun's Avatar
Truck went into limp mode and the MIL light came on. Keyed the ignition and code # 0606 came up. ECM failure, internal fault. Let it set for 15 minutes and it took off and never recured. Will these ECMs do this a few times before they strand you or should I just replace it? 209,000 on the clock. Twogun
Old Nov 12, 2010 | 01:49 PM
rebal's Avatar
usually they quit all together
the electronics can develop whats called tin whiskers (thank you EPA ) from the lack of lead in the solder then it shorts them out or makes them start doing weird stuff keep an eye on it a new ECM is around $500 +-
Old Nov 12, 2010 | 02:12 PM
BigIron70's Avatar
Cummins Guru
I would be shopping for a good price on ECM
When Monitored and Set Condition:
P0606-ECM FAILURE
When Monitored: Key on or Engine running.
Set Condition: Internal ECM error.
POSSIBLE CAUSES
ECM
TEST ACTION APPLICABILITY
1 Turn the ignition on.
NOTE: This DTC is caused by an internal Engine Control Module failure.
Repairs are not possible to the ECM.
Is the good trip counter equal to 0 for DTC P0606?
All
Yes ! Replace and program the ECM in accordance with the Service
Information.
No ! Test Complete.
146
DRIVEABILITY - DIESEL
Old Nov 12, 2010 | 06:26 PM
Twogun's Avatar
cost!
Ecm without program list for $1195. Dealer wants list plus $120 to program. Mopar parts online is $865. Dealer service dept said they will install and program my part so looks like that's the path I'll take. Ouch! Twogun
Old Nov 13, 2010 | 09:40 AM
homewrecker's Avatar
Do a google search for auto ecm's. You will find several for less than dealer price or even look into the possibility of having yours repaired.
Old Nov 14, 2010 | 01:33 PM
BigIron70's Avatar
Cummins Guru
I don't think you can buy new one anymore they are all remans. Did you pull the connectors off and make sure there is no water or corrosion there?
Old Nov 14, 2010 | 07:10 PM
WestTN's Avatar
Check the plug on the ECM before you spend any money. t could be loose, or water could have gotten into it.
Mark Hodowanec
Sep 1, 2009 08:17 PM
Mark Hodowanec
Aug 26, 2009 05:55 AM
Mark Hodowanec
Aug 24, 2009 07:00 PM
Pitz
21
Jun 1, 2008 10:32 PM
