engine surge
Old Nov 7, 2010 | 02:37 PM
team249's Avatar
engine surge
My 2000 ram 3500 has an engine surge between 40 to 45 mph. It only happens when I'm stuck at that mph. If I can get through to high gear without getting held up @ the 40 to 45 mph area It seems normal. Any help would be greatly appreciated.
Old Nov 7, 2010 | 02:40 PM
baddodges's Avatar
is it falling back and forth from 4th to 3rd gear?
Old Nov 7, 2010 | 03:11 PM
team249's Avatar
doesn't seem to be. I had this situation happen several years ago with this truck and mech. determined it was the alternator. can't believe it could be happening again.[IMG]file:///C:/Users/RENTAL%7E1/AppData/Local/Temp/moz-screenshot-1.png[/IMG]
Old Nov 7, 2010 | 04:15 PM
rebal's Avatar
it could be the alt causing the O/D to kick in and out.if it doesn't feel like its shifting then its probably your APPS failing
Old Nov 7, 2010 | 04:45 PM
baddodges's Avatar
let me know if its your apps,there is a way to fix it so you never have that problem again.at no cost
Old Nov 14, 2010 | 12:00 AM
Mike Perez's Avatar
sounds like bad grounds clean all connections including the gound on the engine block underneath before you spend money.
Mike
Old Nov 14, 2010 | 08:29 AM
Maybe that is what is going on with my '01.
I seems to surge 125RPM or so if I hold steady low throttle.
It does it quickly like a three or four surges in less than a second.
If I drive it at more than 1/4 throttle it seems super smooth and with lots of power.
I got no codes when I used a scanner.
I will check the grounds, as it would be a sweet cheap fix!
Old Nov 14, 2010 | 07:50 PM
team249's Avatar
thanks!
thanks to all who responded. ultimately it was a loose ground on the battery side of things. guess I'm just getting old! Need to get up on the wheel next time i tighten things. Thanks again!
Chaddiesel
Jan 11, 2005 06:41 PM
chrismez
17
Sep 17, 2004 09:26 PM
ozzie
Apr 20, 2004 01:24 PM
jpher
Jul 19, 2003 05:13 PM
farmerd
Apr 14, 2003 10:23 PM
