Limited Slip or is something else wrong?
Old Apr 4, 2014 | 03:12 AM
mstep3's Avatar
Is it normal to be able to feel the limited slip in the rear end grabbing when backing up & going forward with wheels turned? Lately it seems that I can feel it a lot more than it used to. I changed oil in the rear end about 15,000 miles ago & used Amsoil 75W-110. Just last night I tried adding another bottle of the Mopar Limited Slip in it, but it didn't seem to make much difference.
It's not making any kind of noise, but it just feels like a grinding sensation when you back up slowly with the wheels turned slightly. Mostly when backing up on concrete. Don't get the problem at all when going forward or backing up straight........
Thanks for help or suggestions.
Old Apr 4, 2014 | 04:51 AM
JRMason's Avatar
It could be the clutches in your limited slip are gummed up. THis generally happens more often on higher mileage vehicles or vehicles that have been ran with the same gear oil way past the scheduled interval. It happened to me on my former 00, but I could actually feel it chattering going around a corner. I pulled the whole assembly and set it on my bench and liberally flushed it with brake cleaner. I think I used close to 2 cans on it, then blew everything out with compressed air. It took care of all my chattering problems and I put about 30k miles on the truck after that.
Old Apr 4, 2014 | 05:56 PM
mstep3's Avatar
Thanks......It's definitely not a chattering.......I can't hear noise........It just feels like a vibration or grinding sensation in the drive train when moving very slowly & turning.......The truck only has 60,000 miles on it so I'm wondering if it's not the Limited Slip & something else may be causing the problem........
Old Apr 5, 2014 | 01:13 PM
SIXSLUG's Avatar
I'd pull the cover and visually inspect it.
Too much additive isn't going to fix a mechanical issue...
If your gear oil hasn't been contaminated by water or cooked there really isn't a change interval. It's a closed system with no combustion element, so synthetics should last a long time...
Old Apr 5, 2014 | 03:48 PM
KATOOM's Avatar
If you're concerned then dont wait for something big to happen. Just pull the cover off and see how everything looks. If you find lots of metal shavings or and chunks of stuff then thats not good. Also, I though Amsoil didnt need friction modifier.
Old Apr 5, 2014 | 06:28 PM
SIXSLUG's Avatar
I know Royal purple doesn't need FM...Mine works fine without ever adding any and it is at 137,000 miles...
Old Apr 5, 2014 | 06:47 PM
KATOOM's Avatar
Thats true SIX. I've changed my Royal Purple twice and its never needed any additive. But for some reason I thought the same applied to Amsoil.
Roughneckin
Jul 16, 2008 11:20 PM
OOPS
May 19, 2006 08:15 AM
shawn085
Nov 21, 2005 12:46 PM
dkinzer
May 23, 2005 08:57 PM
Srigs
Nov 13, 2002 09:30 PM
