Lift pump shoping
Old Feb 7, 2006 | 08:04 AM
spinone's Avatar
Lift pump shoping
Hi all, I think im in the market for a new lift pump. My fuel psi is slowly droping can anybody send me to the right place for buying a new one that dont cost an arm and leg. thanks.
Old Feb 7, 2006 | 12:41 PM
jerky1280's Avatar
I'd be interested as well. Just want a spare to keep around.
Old Feb 7, 2006 | 12:54 PM
6WHEELER's Avatar
depends on if you want to go back with a stock liftpump or go aftermarket"FASS, Airdog" I'm running the FASS system with replaces the lift pump and stock filter.
Old Feb 7, 2006 | 12:58 PM
jerky1280's Avatar
Personally, I'm looking for a stock replacement as I'm still under warrantee.
Old Feb 7, 2006 | 01:01 PM
99 cummins's Avatar
About the only choices you really have are FASS, Walbro, Product Engineering"PE" and Holley Blue and Black. If you do a search on any of these the pro's and cons of each have been argued about all over this site. There is good and bad experiences with all of them. I forgot to mention back to the stock pump which is a Carter.
Old Feb 7, 2006 | 01:44 PM
jeeptjstud's Avatar
I like my bullydog pump. I was running about 12 idle and 2 WOT, Installed that and now up to 19 idle, and 10 WOT
Fairly cheap as well-- ~$230
Old Feb 7, 2006 | 07:23 PM
Dr. Evil's Avatar
Most recommend against the "new and improved" in-tank pump - which is the only pump you can get from a Dodge dealer.
A cheap place for a stock pump is:
http://www.hoeslidiesel.com/
Old Feb 7, 2006 | 09:22 PM
houndawg's Avatar
Anyone using a RASP pump?
Old Feb 8, 2006 | 07:56 AM
mini14's Avatar
look into the fuel manager system from scheid diesel it is a compact efficient system manufactured by stanadyne. I dont believe in adding anything to my system, but if i did this would be it.
Old Feb 8, 2006 | 07:57 AM
Geico266's Avatar
e-Bay has cheap stock pumps.
Old Feb 8, 2006 | 01:29 PM
docauto's Avatar
The Carter has done fine by me, 100K+ miles on it, 16+psi at idle, 13 at WOT at 32psi boost. Napa has them at $160. (I am carrying a spare...)
Dave
Old Feb 8, 2006 | 03:25 PM
fred hartson's Avatar
Lift Pump
My 99 with 147,000 was hard to start in the mornings so I replaced the lift pump with a new Cummins pump. It didn't help. The problem was a check valve inside the fuel tank that let the fuel drain back into the tank after 6 or so hours and caused starting problems. I then replaced it with the in tank pump and it starts fine.
Old Feb 8, 2006 | 03:52 PM
hamilton71801's Avatar
I got a Carter at Orielly's for $230 with a lifetime warranty.
Old Feb 9, 2006 | 09:35 AM
jaxworks's Avatar
Ebay...they are all over at about $100
Old Feb 9, 2006 | 10:51 AM
Patrick Campbell's Avatar
So does anyone know the difference between an OEM Carter and a 4601 hp ?
