lift pump,need help fast
Old Jan 10, 2008 | 03:04 PM
jivemother's Avatar
Exclamation lift pump,need help fast
did i fuel press test after the filter on my 01 ,bad news ....truck not running with the lp running i got 5 lbs ,start the truck, gauge goes to 0-1 lbs,reve it up, 0 lbs new fuel filter also ...... time for a new lp,,80,000 miles on the factory.
so what do u guys think, do the in the tank mod or just a new lp???? or do some hard core lp set up ;like holly or fass , truck is a daily driver no mods realy i am geting a 04 ctd in about 6 months so i dont want to spend alot of money but i dont want to screw someone else down the road...
Old Jan 10, 2008 | 03:14 PM
Dr. Evil's Avatar
Dont do the intank pump!!..if you are selling the truck in 6 months just get yourself a new Carter or a big line kit and Holly Blue on the frame.
Old Jan 10, 2008 | 03:28 PM
used-kubota-man's Avatar
Get you a Holley Black pump off Ebay and mount it near the tank.
Old Jan 10, 2008 | 03:32 PM
lotero's Avatar
The genos relocation kit with a holley blue will run you a little over 200 bucks but is all you need.
Old Jan 10, 2008 | 11:37 PM
robert78.5's Avatar
I am looking on ebay and there are 2 styles of Holley Blue pumps, one is $49.00 and the other style is $150.00. They both push 140 gph at 14 lbs pressure. Which should a guy order?
Old Jan 11, 2008 | 12:00 AM
wjbell's Avatar
I just did a holley blue on the frame along with my current intank pump. Go to Autozone and you can puck up a holley blue for about $120. I also got 14' of diesel rated fuel line and ran it from the top of the tank, to the holey, to the banjo on the fuel filter inlet. Bought my pressure from 5psi to 20psi. I actually lowered the pressure a little by cutting the spring in the holley. Just make sure you remove the screen from the holley if you get one.
Here's my post on it:
http://www.cumminsforum.com/forum/405546-post25.html
Old Jan 12, 2008 | 05:16 PM
Blast54's Avatar
Thanks for the pics.
What do you run the "hot" wire to on the Holly?
Thanks
Bill
Old Jan 12, 2008 | 07:22 PM
safirenfish's Avatar
what screen did you remove? and did you also not use the pressure regulator? that is the same pump i put on my truck and am pleased with it. have had it on the truck for about 9 months now and no problems. i put the pressure regulator on with mine....was thinking about removing it though.
Jim Lane
Dec 7, 2015 09:16 PM
feets
Dec 11, 2011 03:35 PM
EdmontonCanada
37
Dec 9, 2009 03:18 AM
wwm
Feb 26, 2009 08:37 PM
trik396
Mar 14, 2007 07:57 AM
