lift pump after deal replace vp44
Old Oct 3, 2006 | 11:35 PM
Teamropinram85's Avatar
i was also wondering since the deal relocated my lift pump to my tank if i could add another pump in between the pumps cuz i m only get 10 psi at idle i want more .
Old Oct 3, 2006 | 11:50 PM
Marine's Avatar
Veteran: Marine Corp
Go to www.vulancperformance.com and get the big line kit.
And yes, you can put another pump inline.
Old Oct 4, 2006 | 11:37 AM
genesis's Avatar
I just added the Holley Blue on mine and I cant make it go below 10psi at WOT. Love it!
Old Oct 4, 2006 | 11:47 AM
blackdiesel's Avatar
Registered
I put a blue on Dad's truck with the in tank and his stays between 20-15 at all times
Old Oct 4, 2006 | 05:15 PM
Snapper's Avatar
How many miles does your truck have?? I mean Is it even worth it to get a fass system or somethin like that if the truck is still under cummins warranty??
Old Oct 4, 2006 | 08:57 PM
it just turned 100,000 mile a month ago
Old Oct 4, 2006 | 10:40 PM
Mopar1973man's Avatar
Marine is right... Go with the big line kit and add a Cummins Campaign pump (PN#4090046) for a helper pump.
Old Oct 5, 2006 | 02:15 PM
ram23's Avatar
Smile
I had already installed the vulcan kit and gages after Dodge replaced the lp with an intank pump. At that time I had 11 @ idle 8.5 at WOT. This week those press. dropped by 1psi and filter change did not help. Today i installed the carter pump i had already bought from cummins on the frame rail. Now working in conjuction with intank pump, I see 25 at idle, 23 WOT. Looks like the best solution.
Old Oct 6, 2006 | 07:32 AM
Marine's Avatar
Yes. So just the Carter would give you about 15.
That's good.
Old Oct 7, 2006 | 09:41 AM
scook6's Avatar
I too am getting ready to add a campaign pump as a helper pump. Was wondering if anyone makes a tee to plumb the electrics in where the harness is added for the intank setup? Or if not does anyone know the correct wiring for this setup? Thanks
2002 Q/C 4X4
Old Oct 7, 2006 | 04:48 PM
Sixpack's Avatar
2002 Q/C 4X4
I added a Carter 4600 (7psi) where the "old" lift pump used to be (I have the tank pump also). Solid 15 psi at idle. I also have the Max Flow lines and fitting that are 8-an.
As for the tee for the electrical hook up, I used a harness that came with one of the lift pumps I had bought. I spliced into each wire to form a tee. I unplugged the stock harness that now is firing the relay for the ITTP and plugged in 1 end to it the other end back into the relay and the tee side powers my 4600. Works great! I just hope this Carter lasts longer than the other POS!
Good luck, Phil
Totallyrad
Jul 31, 2014 04:34 PM
jj3500
Mar 6, 2013 06:10 PM
schu777
Sep 10, 2009 08:50 AM
Justwannabeme
Jun 5, 2006 08:40 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
