Lift pump
Lift pump
There seems to be alot of knowledge here, so ive got a question for u guys. Im at almost 110k miles on my 01 ram. From reading some of these posts it seems as though i should be thinking about replacing mine. My questions are 1-is the pump inside the tank 2-what kind of pump can i use, can i use a holley or is there a special pump, i want to do this right but not spend a ton of money 3- what fittings will be required 4-how many psi should be going to the injection pump. I think thats all for now. Any help is apprecieated. Ryan
Please see this link on the fuel system components and location. Once there you can look around and find out other things you may want to see. The fuel pump is located on the left side of the engine. My first pump went 95K. I caught it just in time. There is also a test procedure at this site. If you can't find it let me know.
http://dodgeram.info/tsb/recalls/Notice878.htm
Dave
Dave
Ryan, there's a lot to learn! A couple of things you might do is first of all, fill out your signature line so we know at a glance what your rig is and how it is configured. Secondly, use the search feature on this forum and you'll get lots and lots of answers, and most of them pretty good. And one more thing: if you don't at least have a fuel pressure gauge, you're flyin' blind; you've gotta have one! There are good sites to get hardware at, such as Diesel Manor, Geno's Garage, and Transitowne Dodge in NY state if you want MOPAR at a discount. Hope this helps.
Like yukon said, get a fuel pressure guage, either in or out of the cab. in-cab is preferable, but under hood fine for starters. If you have 12psi or above at idle your probably alright for now. superduty has a couple of good threads in the gen diesel forum, it is alot of reading but is very informative. He is using a hi pressure pump regulated down to feed his cummins/ford conversion.
Originally Posted by Dr. Evil
Not really....you need the incab guage because you need to see how well the lift pump is working at Wide Open Throttle (WOT)....the lift pump pressure at idle is essentially meaningless.
loosing power under a load
i have a 2002 3500 dodge cummins. 5in exhaust and hypertech chip. when i go under a load or up to 3 rpms it cuts out. have replaced the apps sensor and i am going to get another under warranty. new air and fuel filters. 161,000 miles. any suggestions?
Warranty Length
At a 161,000 miles where did you find an extended warranty,I want one!
Originally Posted by ryan2001
Thanks,guys I guess i better be getting a pressure guage, wheres the best place to get one. Oh yea i think i fixed my signature
Welcome to DTR
Originally Posted by RATTLINRAM
You have a good point,,,,,,,,,,,,, However,,,,,,,,, under the hood is better than nothing and if the pressure is below 10 psi at an idle,,,,,,,, you can be assured that you are in need of a lift pump.
But, for $19 why not have an incab FP guage?:
http://www.dieselmanor.com/dipricol/...vreduction.asp
Ok guys heres what i have. I used a standard fuel pressure test guage today to see where i stand. Its an actron test guage. I hooked it to the fuel pressure test port.......................and absolutely nothing, at all, needle doesnt even move. is it possible im using the wrong guage. And also anyone have any links for in cab guages?? Thanks Ryan
Look in the end of the hose you connected.
Heres a good spot for gauges:
www.dieselmanor.com
You don't need anything fancy, I think a f/p gauge with related tubing is about $35.00
Search threads here for needle valve installation.
