Leak at Pump inlet
Old Mar 13, 2006 | 06:26 PM
sosborn's Avatar
Leak at Pump inlet
I installed a FPG and ran the braided line off of the Inlet to the IP where the shrader valve was. I know most guys run it off the bottom of the filter, and I'll probably end up moving i there when the weather gets warmer, but when I installed the thing it was freezing and I just wanted to get it working. Anyway, after the install, I seem to have a every so slight leak around the banjo bolt in the inlet port. I did not use any teflon tape - I read that that was a bad idea because the fuel will eat it away and it can get lodged in the pump.
Is it safe to keep tightening the bolt? how tight is too tight? Or is there some other type of tape or sealant to be used on the brass fittings?
Thanks,
Sam
Old Mar 13, 2006 | 08:08 PM
Dr. Evil's Avatar
I assume you have bare threads....if you use some #2 Permatex or some teflon paste (Loctite PST or Swagelok SWAK)...the leak will be gone.
Old Mar 14, 2006 | 06:35 PM
sosborn's Avatar
Yes, bare threads at this point. Thanks for the input.
Sam
Old Mar 14, 2006 | 07:11 PM
Shovelhead's Avatar
Administrator / Scooter Bum
You DID put the sealing washers back, right?
There should be two. one on either side of the fuel line "banjo" part.
The bolt head seals at the top, the fitting in the housing at the bottom.
Sorry if this sounds silly, but just want to be sure.
Old Mar 15, 2006 | 11:37 AM
sosborn's Avatar
yes, I used the new washers that came with the banjo bolt.
Dean Snow
Apr 18, 2010 06:19 PM
Jim5870
Apr 5, 2010 08:49 PM
ZSkibo
Sep 16, 2009 07:58 AM
superdodge
Mar 25, 2008 03:34 PM
CarBizIndio
Jun 23, 2007 09:37 PM
