killer dowell pin
Old Mar 20, 2006 | 04:35 PM
Mcmopar's Avatar
My 98.5 24 valve had a pin that was part way out, I pounded it back in and tabbed it. FYI.
Old Mar 20, 2006 | 04:41 PM
Geico266's Avatar
You are welcome Truckman!
Old Mar 20, 2006 | 04:46 PM
piperca's Avatar
Originally Posted by Truckman
piperca ,,, You mean to say there are NO 24 Valve CTD with this problem?
All I am saying is that the "left over" cases from the 12 valve engine, being used on the 24 valve, is not possible ... they will not support the use of a VP44. If Cummins screwed up and didn't fix the problem when they retooled, like they said they did, then there could very well be a problem. I find it hard to believe that they would not have addressed it, but believe what you want to believe. I'm not worried about mine!
Let me find the thread, it was a P-pump 24 valve thread, and I'll post a link.
Here it is: https://www.dieseltruckresource.com/...ghlight=p-pump
Old Mar 20, 2006 | 08:38 PM
MKELLY's Avatar
Just when I felt like that was one issue I wouldn't have to deal with . I've read other posts that also refer to a KDP problem on early 24v models???
Old Mar 20, 2006 | 10:13 PM
piperca's Avatar
Don't be going high and to the right on us, calm down and research it. I'm quite happy knowing mine is fine!
Old Mar 21, 2006 | 03:09 AM
AlpineRAM's Avatar
I've done the KDP tab on several 12Vs and also on 2 24Vs from early production dates where the KDP had worked out until it was protruding from the surface about 2 mm. (Which to me is a sign of no shoulder being present. )
I do not know of any way to verify whether the case is updated with a neck or shoulder or not until the cover is removed and the dowel pin hole is inspected.
The probability of having the "dangerous" case seems to get lower for the later production dates.
Just my 2c
AlpineRAM
Old Mar 21, 2006 | 06:43 AM
Geico266's Avatar
I don't think there is enough room for the pin to fall out if the "boss" is present. The pin will just hit the timing cover? In other words, the pin has to travel farther to fall out because the boss holds it longer. That is what I always assumed, I could be wrong.
In any event I took a punch and dimpled the hole on mine. It ain't goin no where.
Old Mar 21, 2006 | 11:49 AM
Gotlift01's Avatar
I was just looking on BD's website and I noticed they had a KDP kit for 12V motors and 24V motors.......so I guess it must have happened on a few 24V's. My guess is the early early 24V's were the canidates. Glad mine is a 2001, cuz I'm not to worried about.......hopefully they fixed that by the time mine was born
~Nick
Old Mar 21, 2006 | 03:40 PM
Truckman's Avatar
Talking Dont Worry BOUT IT!!
~Nick
Your all set Dont worry bout it !!!!
You DONT have a #53 Block do you????
Old Mar 21, 2006 | 06:03 PM
tempoffroad's Avatar
i have the 53 block not sure about the kdp truck was born 3/99 i just ordered the vulcan ip relocation kit and just bought the truck this past Saturday now im worried about the ip's the 53 block and now the kdp.
Old Mar 21, 2006 | 06:14 PM
Truckman's Avatar
Talking Welcome to DTR
A Proud owner of a #53 Block,,,,WOW Me too ,,,,BUT Not for long ,,,,, See my Gallery.. hahahahahahaha OK I'll Shut up Now
Good Luck
Old Mar 21, 2006 | 06:28 PM
Geico266's Avatar
Only a small % of the 53's crack, relocating the LP is a very good thing, I would only check the KDP if you have a oil leak around the shaft seal, or timing case. If it really bother's you just buy the kit & do it. 4-5 hours you'll be done and know for sure. The kit is cheap.
Drive it like you stole it.
Old Mar 21, 2006 | 10:23 PM
edy's Avatar
edy
Originally Posted by Jim Dynomite
Nope,........... but you could have a 53 block! .
Did I say that out loud?
...........Jim
I have a mexican block and and a fuel pressure gauge. sinserly edy
ranchertx
17
Mar 11, 2012 01:28 PM
CactusPete
Nov 17, 2011 10:37 PM
olsenam
May 31, 2006 07:19 PM
edy
Mar 19, 2006 09:04 PM
edhehde
Feb 28, 2004 09:50 PM
