Intermittent Power Loss
I have a 99. The lift pump and VP were changed out less than two years ago.
I have been having a problem with my truck over the last 3-4 days. Driving at highway speeds there is a quick miss and then no power. I can not accelerate at all. When it has happened I have down shifted and once things were normal again and the second time it happened it did not fix the problem but when I shifted back into 5th gear the problem was gone.
Any ideas on what the problem might be?
You need to put in a new lift pump before replacing VP. Go aftermarket m maybe a FASS or Raptor. I bought a truck with a fresh VP and a new lift pump, OEM. the lift pump put out 3PSI. That is what killed the VP. I took out perfectly good OEM pump and put in a FASS pump with out the air eliminator and now I have 16 psi and don't worry about the VP.
RHC
Aug 12, 2019 03:32 PM
