Intermittent brake issues
Old May 11, 2015 | 11:50 AM
mpfireman's Avatar
My 98.5 cummins has a braking issue. Sometimes when you apply the brakes you have to push the brake peddle quite hard to stop, other times it works better, but not really that good. Do you think that the power booster is not working properly, and if it needs replacing, how hard is this job? i know the price of a booster is around $ 200.
Old May 12, 2015 | 11:35 AM
AlpineRAM's Avatar
I'd check the power steering fluid first-
Is there enough?
Does it smell burnt?
If everything is OK there I'd continue with testing whether the power steering does work when you have the "hard pedal" issue.
Just my 2c
AlpineRAM
Old May 13, 2015 | 08:58 PM
jrs_dodge_diesel's Avatar
Do you have hydroboost or vacuum boost?
I don't remember what year they switched, and the source of the problem can be different depending on what you have.
Old May 14, 2015 | 03:53 AM
AlpineRAM's Avatar
My 98.5 and my friend's 97s have hydroboost.
On one of the 97s I had to clean out some coked oil from broken down PS fluid to get the hydroboost to work correctly again.
Old May 23, 2015 | 09:07 AM
mpfireman's Avatar
My 98.5 has the hydro boost. Rebuilt ones cost about $200, and wondering what test can be made to know if it is bad? And if bad, how hard is it to change?
smokester
May 27, 2011 05:31 PM
Bobcat698
Nov 21, 2005 03:19 PM
Alexjoz
Sep 1, 2005 10:00 PM
Begle1
Jul 11, 2005 08:43 PM
DHeadington
Mar 29, 2003 09:25 AM
