Intermitant Tach Reads 0
Old Mar 7, 2011 | 10:00 AM
307Kenworth's Avatar
Tach will intermittantly drop to 0 for a while then pick back up,
Throws codes:
P0500
P1693
P1687
I'm thinking I need to pull out and clean my vehicle speed sensor, the one on top of the pumpkin? Anyone had this combination before?
Old Mar 7, 2011 | 10:07 AM
rebal's Avatar
0500 will trip if you the tires you probably need a new cam sensor or you could have a bad or dirty conection on the back of the gauge cluster
Old Mar 30, 2011 | 05:01 PM
Bump
All has been fine it hasnt acted up much lately, until today. I'll be as descriptive as I can about what all happened.
Right after starting the truck, tachometer worked for about 2 seconds and dropped to zero. I pulled out Only code 1693. As long as the tach was reading zero there was no little puff of black smoke coming out of the tail pipe and the truck felt really doggy. (No I am not talking a bunch of suped up high performance blacking out black smoke, just the little puff you get when you get on it, basically shows the engine is feeding a little fuel to get the turbocharger lit.) After 3-5 minutes of this they tach would pop back on and work normally, the bit of smoke under acceleration came back, truck felt less doggy, etc.
After doing some research I'm thinking it's more than likely my cam sensor on it's way out, But before I go throwing parts at it I thought I'd like to ask some people on here with the latest things its doing.
Old Mar 30, 2011 | 05:08 PM
I also found it interesting that only 1693 code came up instead of the ones that accompanied it earlier this month.
Old Mar 30, 2011 | 05:18 PM
Tate's Avatar
Cam sensor is my bet.
Old Apr 1, 2011 | 06:41 AM
mini14's Avatar
^^^^^tach dropping to zero is the sign of a bad cam sensor.
TIMMY22
Nov 25, 2009 11:34 AM
03qclb5spd
Apr 3, 2007 11:42 PM
jgiachino
Feb 16, 2006 02:50 AM
Winr
17
Jul 21, 2004 08:15 PM
slam
Jul 28, 2003 07:09 PM
