Lost Tach and Overdrive (intermitant)
Old Nov 20, 2009 | 03:11 PM
TIMMY22's Avatar
Truck sometimes looses tach and O/D also stops charging. Starts off in third gear.
Then you start it up the next day, everything is fine till all of a sudden, same thing.
I want to say PCM trouble.
Any ideas?
Thanks in advance!
Old Nov 20, 2009 | 05:11 PM
Lil Dog's Avatar
Have you checked the engine crank sensor? sounds to me like it may be failing once it gets hot, typical of coil type sensors. Its mounted on front of the engine just down beside the water pump pulley facing the balancer.
Old Nov 20, 2009 | 05:36 PM
TIMMY22's Avatar
Oh, the engine speed sensor? the one that you remove during a KDP job?
Old Nov 20, 2009 | 06:12 PM
patdaly's Avatar
Yep, bet you either have a bad CPS or wiring issue......
Old Nov 20, 2009 | 07:26 PM
TIMMY22's Avatar
Ok,
Thanks!
Old Nov 25, 2009 | 08:46 AM
TIMMY22's Avatar
Ok,
Replaced the sensor and so far so good!
Dodge wanted $120
Cummins $63
So you know where I ended up.
Thanks Again! Happy Thanksgiving
Old Nov 25, 2009 | 11:34 AM
infidel's Avatar
It's even cheaper at the autoparts.
The same ESS was used on most Chrysler vehicles of this vintage, plenty popular and available.
307Kenworth
Apr 1, 2011 06:41 AM
randyswelding
Oct 6, 2008 06:23 PM
Toomany Tools
Aug 28, 2008 06:59 AM
banks-powered
Jan 8, 2008 05:49 PM
slam
Jul 28, 2003 07:09 PM
