injector problem
Old Jan 20, 2007 | 07:31 PM
solostyle1's Avatar
injector problem
I recently installed the EDGE 150hp injector nozzles. The first spin around the block revealed a problem. When the truck is running it is building SERIOUS pressure in the fuel tank. I had to drive it home with the fuel cap off because of the pressure. The whole time it blows out diesel fumes. If i cap it, then it would literally explode my tank. I starting to take apart the engine to check my work and noticed the 1st injector "coppper" seal was seriously damaged. Injector #2 was fine. Thats when I stopped. I have to wait till Monday to order the new seals. Do you think that is the problem with the pressure build up? Fuel being sent back into the tank? The injector was dry and black, not oily like the other!
Old Jan 22, 2007 | 07:21 PM
solostyle1's Avatar
no one has any clues?
Old Jan 22, 2007 | 08:47 PM
JD730's Avatar
Your on the right track, definitely sounds like you compromised an injector sealing washer, #1 as you said was damaged, and it was pushing compression right into the return line back to the tank.
Old Jan 23, 2007 | 11:24 PM
gsjr24's Avatar
Yes definetely. exactly like jd said I seen it happen too!
Old Jan 24, 2007 | 12:12 PM
John DiMartino's Avatar
Do not drive the truck until its repaired! You can also be pushing fuel into the oil as well.That problem will be even bigger.
gablekevin
Sep 19, 2006 12:12 AM
kawi600
Jan 26, 2006 10:19 AM
G-NOTE
Sep 1, 2005 06:36 PM
oscaroc
Apr 2, 2005 12:14 PM
