injector install how to
Old Jun 28, 2009 | 09:05 PM
benroberts3605's Avatar
I just got my new injectors in the mail today and im looking for a link or any info that will aid me in this process, i have never done this before. I guess im looking for a step by step procedure. I do have a puller so that will not be an issue. Thanks guys
Old Jun 28, 2009 | 09:26 PM
johnh's Avatar
https://www.dieseltruckresource.com/...jector+install
Old Jun 28, 2009 | 09:48 PM
what do you think it will take time wise, I am a mechanic so im not a novice but this will be my first injector install
Old Jun 28, 2009 | 10:10 PM
Mike D's Avatar
1.5 hrs start to finish is a good average for first timers.
Old Jun 29, 2009 | 10:22 AM
ldornak's Avatar
While you are in there, might as well check your valves.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
I adjusted my valves at the same time as my new injector install. Adds another 30 minutes to an hour.
Old Jun 29, 2009 | 07:02 PM
I actuall just did my valves, for the longest time i was under the impression that you had to pull the rocker arms off to do the injectors thats great that you dont have to i dont know where i got that from.
Old Jun 29, 2009 | 07:50 PM
now what are you guys using to pull the conectors with and is a new o-ring necessary
Old Jun 29, 2009 | 10:03 PM
johnh's Avatar
i use a little screw driver,i've done the swap 4 times and never changed o rings...... but look at them close and decide
here are some more detail
http://cumminsdatabase.com/pdf_files...structions.pdf
Old Jun 29, 2009 | 10:13 PM
AggieJustin's Avatar
Definitely put new copper washers on when you do the swap. Since that usually required a trip to Cummins for parts, I usually grabbed new o-rings as well just for peace of mind.
Old Jun 30, 2009 | 10:50 AM
I think I got one more question on the instructions. what do they mean when they say Remove the 8mm forward most injector retaining clamp bolts only. It is not necessary to remove the rear injector retaining clamp bolts
Old Jun 30, 2009 | 11:15 AM
ldornak's Avatar
The front of the retainer is drilled. The back of the retainer is open ended and slides under the rear retainer bolt. All you have to do is remove the front bolt and then lift and slide the retainer out.
Old Jun 30, 2009 | 06:44 PM
allright thank you guys for the help
gablekevin
Sep 19, 2006 12:12 AM
kawi600
Jan 26, 2006 10:19 AM
G-NOTE
Sep 1, 2005 06:36 PM
oscaroc
Apr 2, 2005 12:14 PM
