Injector Cross Over Tubes
Old Sep 28, 2008 | 12:28 PM
Dinner's Avatar
Hello,
I ordered some Injectors the other day, figured I might as well remove my stock ones being as my engine is 1/4 apart anyways. I got the injectors and cross over tubes out easily, however I am wondering if this is normal on the tubes? 2 of the tubes are fairly clean, the other 4 are like this:
Is this normal like blow by almost, or should the o-rings/tubes be replaced?
Thanks!
Old Sep 28, 2008 | 01:00 PM
dozer12216's Avatar
O rings should be replaced. Make sure injector hold down bolts and injector lines are properlly torqued and recheck after couple hundred miles. Don't ask why.
Old Sep 28, 2008 | 02:56 PM
Dinner's Avatar
Thanks Dozer,
Am I able to get away with regular style o-rings that you get at a hardware store? Or do I need a special type of o-ring that is made for these tubes?
Old Sep 28, 2008 | 11:00 PM
johnh's Avatar
Originally Posted by Dinner
Thanks Dozer,
i think you should get them from cummins.
i don't know if the ones from lowes or home depot are made to take the heat or oil
Old Sep 28, 2008 | 11:59 PM
MikeR's Avatar
The generic hardware store O rings will turn too soft.
Cummins sells the proper O rings. I'd just clean off the crud and keep running them.
Old Sep 29, 2008 | 08:02 AM
Dinner's Avatar
Do you fellas know how much the o-rings go for these days? I wouldn't think they would be too expensive, but then again,lol.
Thanks!
Old Sep 29, 2008 | 10:27 AM
johnh's Avatar
Thanks!
about $1.50 each from industrial injection
Old Sep 30, 2008 | 04:23 PM
Dinner's Avatar
Thanks John.
I'll give them a call and see if they have them in stock and if they ship to Canada.
hot_runner58
Sep 30, 2014 07:05 PM
dodgediesel
Aug 17, 2011 02:55 PM
bradler
Nov 16, 2010 08:59 PM
taterramin
Jul 4, 2009 10:41 AM
bigfoot
Aug 14, 2004 02:22 PM
