injector?
injector?
how often should injectors be tested.my truck is making too much black smoke.have to leave the box turned off.have about 100k on DD II injectors.The injector pump has 180k on it.
havent found any boost leaks.
DD 2's do smoke a lot. With the lag from your HX-40, and an automatic, a lot of smoke, pre boost would sound normal to me.
If no hard starts or rough idle.... I suspect injectors are ok. Did too much smoke just start to happen??
RJ
RJ
used to run the box on setting 2.smoke not to bad.now it smokes with the box off and doesnt clear up.boost runs up to 30 to 40 pounds.i even get a small cloud when i start it .
TJ0993
Nov 8, 2007 10:27 AM
gablekevin
Sep 19, 2006 12:12 AM
kawi600
Jan 26, 2006 10:19 AM
oscaroc
Apr 2, 2005 12:14 PM
